Old 09-27-2020, 02:09 PM   #1
86Jag
Our Rpod batteries charge at home and in the campsite, but apparently discharge in 2 or 3 hours while towing. Any idea why this is happening?
86Jag is offline   Reply With Quote
Old 09-27-2020, 02:31 PM   #2
Mr. Dan's Avatar
What is your tow vehicle?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 94; booked = 14
Old 09-27-2020, 02:50 PM   #3
bikendan's Avatar
Yep. You need to check the charging pin, in the tow vehicle's 7-pin connector socket.
Equalizer WDH
Old 09-27-2020, 07:49 PM   #4
We tow the RPOD with a 2014 Chrysler Town and Country. Since posting my question, I checked the battery water and found one battery full, but added maybe 3 pints of distilled water to the other. Could it be that I was fooled by the one charged battery when I checked at home by turning on a light, but then had the charge drained by the fridge while driving about 3 hours? I am charging now at home, then will try the fridge on battery a few hours to see if the batteries hold a charge longer.
Btw, I did check the 7 pin connector and was told it was providing current. Thanks for the replies.
Old 09-27-2020, 09:00 PM   #5
86Jag
....but then had the charge drained by the fridge while driving about 3 hours? I am charging now at home, then will try the fridge on battery a few hours to see if the batteries hold a charge longer..
If you are running a fridge on 12v alone that will drain a battery pretty quickly.
Also, the 12v feed from the vehicle probably doesn’t have a large enough wire to keep up.
A battery that requires that much water to be added may be toast.
phipps33 is offline   Reply With Quote
