Breaker could be bad. Easy replacement, just make sure you get one that matches you panel manufacturer. Also check the pedestal voltage. If at a campground and everyone is experiencing heavy use then the voltage could be low. This causes the current to increase and can eventually trip the breaker. It is also not good for the compressor.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
