Old 08-09-2022, 01:07 AM   #1
Chardagha's Avatar
A/C tripping 20A breakers
Hi all, I’ve got an ‘04 5er. Today, I moved her off the slab and onto the street to get ready to travel. She is connected to a 30A circuit while parked and I THINK all is ok.
I connected her to a 20A circuit (not enough extension to reach 30A) and turned on the A/C. She starts fine and runs for 4-5 min, then blows the breaker. I reset the breaker and same thing. I tried another 20A circuit and same thing.
A/C is the only appliance running in the 5r. Do I need to connect to a 30A circuit or do I have another problem?
TIA
Chardagha is offline   Reply With Quote
Old 08-09-2022, 06:03 AM   #2
Oaklevel's Avatar
20A breaker, AC and the converter and a long extension cord. I personally am not that surprised that the breaker is tripping. What guage cord is the extension cord.
Good if it is the campers cord, but the AC and the converter pull around 20A. The converter is always on.
Which breaker is tripping the garage or the camper? I am assuming the garage.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 08-09-2022, 06:34 AM   #3
Georgia Rally Coordinator
aceinspp's Avatar
You need to use the 30amp circuit. AC draws to much for a 20amp circuit. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49 days camped 2021-74 2022-31 days
Old 08-09-2022, 06:40 AM   #4
if breaker in garage tripping .... too much current is being drawn by the a/c and converter. Allow converter to charge the battery before a/c is turned on.
if breaker in trailer for the a/c is tripping
use multi meter to read voltage at a power point in trailer
while a/c is OFF should read 120v
Then start the a/c and watch the meter if it drops much... mine went to 108v
Power cord from garage to trailer is not supplying enough current
I went out and bought a contractor grade power cord 12G wires ... breaker has not tripped since
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 08-09-2022, 07:37 AM   #5
As mentioned... which breaker is tripping? The one in the R/V or in the garage/home?
The length and gauge of this extension cord you are using now that you've moved your R/V to the street is critical. Too small and too long will create voltage loss and not allow the same usage as your 30a shore cord causing breaker(s) to trip.
You say nothing else is on but there are items like the CONverter (that charges the battery and supplies 12v for lighting, etc.) that will always be on unless you turn the breaker for it off.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=95
Old 08-09-2022, 07:49 AM   #6
length of extension cord is not usually an issue unless it is over 100ft...
The gauge is definitely important.
Age and condition can be a factor too ... loose, corroded or worn connections.
coiling a long cord is bad as well as it can overheat more.
Tarpon Springs FL
2022 Salem 24RLXL
Old 08-09-2022, 09:55 AM   #7
Chardagha's Avatar
Thanks for all the info; I forgot to mention that I’m using a 25’ 12 ga extension from the house circuit to the RV, and that it is the house breaker that is tripping. I have a 30’ RV extension cord, but it is not long enough to reach the house 30A supply. I suspect this would alleviate my problem…
Next question; could I replace a 20A breaker on my panel with a 30A breaker to create a 30A circuit?
Old 08-09-2022, 09:58 AM   #8
Just changing a breaker size is usually not a good thing. It has to have the proper gauge wire to handle a 30amp circuit before you should swap the breakers out.
Marc in sunny California
2013 Crusader 260 RLD
2012 RAM 2500 Laramie CTD and 4:10
mmartin_tdc is offline   Reply With Quote
Old 08-09-2022, 10:11 AM   #9
No, do not replace the breaker. The wires for that circuit will not safely handle 30A. Bad Idea. Very bad.
You 20A house breaker is most likely tripping because you have other loads in the house on that circuit. See if you can shut off or remove all the loads in the house. As other have said you should also shut off your convertor and any other 120V loads in you 5th wheel before trying the AC again. I run mine off a 20A house outlet all the time with no issue.
Jim M.
2020 Flagstaff Super Lite 26RBWS
Former: 2017 Rockwood MiniLite 2104S
2015 Silverado 2500HD 6.0L Gas
jimmarako is offline   Reply With Quote
Old 08-09-2022, 10:21 AM   #10
Flybob's Avatar
Are you overlooking something else on that breaker in the house?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-09-2022, 10:25 AM   #11
12 ga extension cord is to small 10 ga minimum then everything else off in camper 120 side .
MR.M is offline   Reply With Quote
Old 08-09-2022, 10:28 AM   #12
You could..... BUT risk of burning your house down
breakers are designed to protect the wires inside your house so they won't melt and start fires if they get too hot.
You could possibly add a 120v 30amp circuit to your existing house panel
If you do NOT know how to.... get an electrician won't cost that much
but in the meantime you could do the following ....
make sure all your 20amp connections are clean and tight fitting
you can change the breaker with a new one the same amps...
breakers have been known to go bad and fail
Tarpon Springs FL
2022 Salem 24RLXL
Old 08-09-2022, 12:59 PM   #13
Double-check that the electric side of the water heater is off. Easy to overlook.
Larry
Larry-NC is offline   Reply With Quote
Old 08-09-2022, 01:04 PM   #14
I have run my AC off a 20 amp breaker, but I know nothing else is on that circuit.
It was for my old pool pump equipment that has been removed. I used my 30amp RV cable to run the distance with a dog bone to a 15amp plug. Runs my 15k AC without issue.
Old 08-09-2022, 01:06 PM   #15
Chardagha's Avatar
I’m back!
As I suspected, the breaker replacement was a bad idea, and thanks for you all making sure that I understood.
Ideally, I would want a 30-40’ 8 ga cord with 30A connectors, but I’m finding that is a unicorn. I will be purchasing a 30’ 10 extension cord and contacting an electrician to see what I can improve on my house panel.
Both of the 20A circuits I used are dedicated outdoor circuits I had installed recently.
Again, thanks to this community.
Old 08-09-2022, 01:07 PM   #16
Chardagha's Avatar
Thanks, didn’t think of that!
Old 08-09-2022, 01:36 PM   #17
Mr. Dan's Avatar
If you will use the QUOTE function, other members will know what you didn't think of.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 109; Booked for 2022 = 14
Old 08-09-2022, 03:25 PM   #18
Why not use the RV's power cord and a 20a to 30a dogbone to adapt the power cord to the 20a receptacle at the house?
2022 MiniLite 2109s
2019 Ranger Lariat 4x4
(We're just getting started!)
JimM2109S is offline   Reply With Quote
Old 08-09-2022, 03:37 PM   #19
That statement scares me a bit.
If you're thinking of hooking up to a 30A plug for a household dryer DON'T. That will not alleviate your problem. Some people here have tried it only to realize that it's a 240V and have burned up most of the appliances in their rig.
A 30 or 50 A RV plug is a whole different animal and you have to have an electrician who is familiar with how an rv plug is wired to install it.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 08-09-2022, 03:59 PM   #20
TIA
The OP stated in post # 1 they had the R/V connected to a 30a outlet and they thought all was fine. They then moved it to the street where the 30a cord no longer reached so they plugged into a 20a outlet using an extension cord.
The 30a R/V outlet they ultimately would like to plug back into is one that they already had been using. At least that's how I read it.
breaker
