The converter charges the battery. The battery powers your lights, propane starters in fridge, hot water heater, and space heater. It also powers any slides, Jacks, stabilizers, etc. A/C powers your fridge, air conditioning, outlets, inverter if you have one, and converter. Most recommend disconnecting battery if unit is left longterm on the converter as the charge it maintains can gradually boil water out of the battery. Certainly check the water level periodically if left connected.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
