Originally Posted by Bama Rambler
If the microwave worked and you have a 30 amp unit. you had 120 volt power to the RV.
This is correct. If the refrigerator's failure to switch to 120v electricity is the only failure (you should forget the absence of the blue cable light as I said above), you should focus your attention on the refrigerator.
Find where it's plugged in at a 110v outlet and meter the outlet to see if it has power. No - then work back to the breaker for the refrigerator. Yes - you should check a couple of fuses behind a black box on the refrigerator's outside face.
