Originally Posted by lchil02
I have a 22 FR Vibe 34BH with 165W solar and a 30 amp Solar Controller to keep my 65W battery charged. I want to replace the battery with 2 100ah lithium ion batteries in parallel. Do I also need a dc to dc charge controller along with an inverter to run my 120v system?
Hoping someone can help!
My battery currently just runs my 12v fridge and slide outs.
Your current converter/charger will charge your new lithium ion batteries to around 85-90% state of charge and your current solar controller, when changed to lithium/LiFePo4 charge profile, will finish the job.
If you wish to charge the lithium batteries while driving ( towing ) then a dc-dc charger is highly recommended. Existing charge circuit from tow vehicle is severely limited in the amount of current it can deliver to trailer batteries so unless one drives all day the batteries will come up short for charge.
A dc-dc charger can be purchased for just over $100 and adding a larger (#6 or bigger) wire fron tow vehicle battery to trailer will deliver 20 amps plus, depending on size of dc-dc charger.
I've done this with my truck and trailer to charge my two LiFePo4 batteries and I always arrive at my next campsite with full batteries.
Sent from my SM-N950U1 using
Forest River Forums mobile app
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
