03-16-2023, 11:33 AM
Kanadian Kamper
Adding portable standalone solar
Anyone out there ever used a portable standalone solar panel or panels to their rig……trailer, 5th wheel or motorhome, USING THE 12 volt socket on the exterior of their living side, usually found underneath the awning.
There are a number of solar panel kits that include a panel(s), controller and an assortment of connecting cords, so that you might be able to position your panels in direct sunlight while the rig might be under trees.
I already have a factory installed 100 watt roof panel, but not always in the sun.
And…….sometimes I might want to use both sources to keep the batteries healthy.
Comments?
Ken and Terry
03-16-2023, 11:54 AM
I have a Renogy 100W suitcase panel with a controller. I also have a 80W panel that I connect to it to give a total of 180W capacity. I connect it straight to the battery on the front of the trailer with the clips on the cable. This works well for me, I plan on adding a SAE connector to the battery box sometime this year. Having the SAE connector on the box, will allow me to connect without opening the battery box.
If the 12V socket you want to connect to is one of the "Lighter" style sockets, then it is probably fused at your power center. This adds length to the total cable run from your Solar Panel controller to the battery. That may cause voltage drop and power loss depending on the wire gauge and length. It will work, but be sure you have the polarity correct at the socket.
2022 Surveyor Legend 19BHLE
2013 F-150 XL Supercab 3.7l V6
03-16-2023, 12:21 PM
500 watts total of portable solar. Works great. The only issue I see is possible thievery.
This Summer I will probable connect all the panels with cable just to make it a little bit harder to steal.
2018 Coachmen Freedom Express Liberty Edition 231RBDSLE
03-16-2023, 12:46 PM
You can find some residential sized panels and NOT connect them with a hinge
they are awkward and heavy enough without joining them.
add a simple aluminum leg / framework to allow deploying and tilting
plus some way to stop them blowing away... tent pegs?
add a good charge controller sized to suit the panels you have..
mount it near battery or busbar
your goal is to make deploying the panels as easy as possible.
Find some affordable used panels in case they walk off during the night....
try this video for a bit of a primer..
Not sure if this one shows his beer can tilt optimizer
I would probably go through a six pack getting the panels adjusted just right!
In case beer can optimizer is not shown
place and hold beer can on the panel surface
tilt / move panel until shadow of the can is evenly distributed in all directions around the can...
Tarpon Springs FL
2022 Salem 24RLXL
03-16-2023, 01:00 PM
Can't speak for all but residential panels as "portables" are just too large to store in an RV or Tow Vehicle while underway to be practial.
Rooftop mounting is a whole different story. They have a permanent spot to travel.
03-16-2023, 01:19 PM
yeah stay away from the over 300W crowd...... not even sure if I can lift them
I want to add framework on the rear bumper
or make a slide so can store them underneath.
will need a good bottom on the slide to protect them.
for now .... I have space on my TV roof racks
Tarpon Springs FL
2022 Salem 24RLXL
03-17-2023, 04:59 PM
Someimes Re- member
Comments?
Yes, I use a 200 watt Renogy Suitcase, connected with a 50ft 12AWG cord to the "Solar on the Side" SAE port. I made the cord, and attached it directly to the Solar Panel output. The cord coils up inside the Suitcase for storage and transport.
I RELOCATED the Solar Controller that was mounted on the back of the panels to just inside the hatch to my pass-thru storage, adjacent to the "SoS" port. I then wired the Solar Controller BETWEEN the "SoS" Port and the Battery. The Controller is mounted on hinges attached to the hatch frame, so it can fold back out of the the way when not in use, or be easily visible by opening the hatch when I want to see what the panel output is.
This set-up allows me to move the Panels around to stay in the sun at the optimal direction and tilt, and allows me to see the Panel output on the Solar Controller while at the TT. It also makes it IMPOSSIBLE to INCORRECTLY attach the Panels to the Controller BEFORE the Controller is connected to the Battery, which can seriously damage your system.
2021 E-Pro E19FBS
250 AH LiFePO4, 190w Roof Solar, 200w Portable Solar, 1kw Inverter, 12v Refrigerator, many Mods
2022 Toyota Tundra, 3.5L V6 Twin Turbo w/Tow Pkg, Rear Air Suspension, Andersen Anti-Sway WDH
03-17-2023, 07:14 PM
“ USING THE 12 volt socket on the exterior of their living side,” is likely under guaged for the size wire needed to get full capacity from any panels. You’d likely be better off going from your Charge controller directly to the battery(ies).
2019 Freedom Express 248RBS
2012 F150 Supercrew 4x4
03-17-2023, 07:49 PM
These side mounted sockets are wired for the 12v power produced by the portable panel's controller output. It won't have any problem carrying power from a controller mounted closer to the batteries. In my TT's case this wire is #10 awg which will easily handle 30 amps for the few feet remaining to the battery.
