Originally Posted by Steelhorzz
I guess that's also a good question....
What wattage would I need?
For charging it's all about amperage, so I don't know how wattage relates.
Bring novice to solar, I'm only going by what I see other people have setup in my RV storage facility, and what's offered for sale on eBay and Amazon.
As far as automotive, I've have learned over the years......
"Bigger IS Better"!!
So if you just want it to maintain/trickle charge your batteries in storage and that is it, then a 100w is overkill (assuming your batteries are full when you put you trailer in storage).
Some basic knowledge
watts = amps X volts
1 amp X 12 volts = 12 watts
2 amp X 12 volts = 24 watts
For my trailer I know I have a .25 amp draw with everything off and battery connected.
So to size a panel for this draw I take:
.25 amps X 12 volts = 3 watts
This is per hour, so for a 24 hour period I multiply 3 watts X 24 = 72 watts for a 24 hour period.
When looking at solar panel wattage that means the watts the panel puts out under peak conditions in 1 hour. So a 100w panel puts out up to 100 watts under ideal conditions in one hour.
Similar situation, if I have my battery disconnected it drains at a miniscual amount (something like .009 amps). So, .009 amp X 12 volts = .108 watts x 24 hours = 2.5 watts a day. So a 3 watt panel would top me off in an hour for a whole days worth of drain.
Most tricklecharge solar setups charge/maintain at a .27 amp rating. which is .27 amp x 12 volts = about a 3 watt panel. For maintainging you could easliy get a 3-5 watt panel and put it in a window and you would be fine.
What you are seeing in the storage lot is people probably use those 100w panel out while they are camping and then use them as a maintainer at the lot. I doubt they bought the 100w and controller for storage lot maintaining. Like mine I bought to use camping, just while not camping I can use it for a battery tender/maintainer since my controller is a 4 stage and goes to float/maintenance mode.
I hope this is the info you were looking for and I hope I made it a little easier to understand
