Old 01-23-2020, 10:20 PM   #1
Another battery question
We have a Cherokee 274VFK and the battery is located in a compartment in front. I would like to install two AGM batteries. Sam's has 12 volt group 31 AGM.
When I look at 6 volt GC2 AGM the CCA is listed. I was in a Batteries + bulbs store today and the lady helping me said all AGM batteries are dual purpose.
It looks like AGM GC2 6 volt batteries are not really deep cycle.
Should I go with two 6 volt or the two 12 volt? I would go with the GC2 AGM if it was a true deep cycle. The GC2 AGM is quite a bit more expensive thatn the Group 31 12 volt AGM.
Thanks for any suggestions,
Willie
Old Willie is offline   Reply With Quote
Old 01-24-2020, 02:43 AM   #2
AGM batteries can be discharged down to 20% compared to 50% for flooded deep cycle. So I would say the battery lady doesn't really know what she is talking about.
At the 20 hr discharge rate a pair of Group 31 = 210 AH and a pair of GC2 = 190 AH. So I would go with the Group 31.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre - Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
Old 01-25-2020, 11:24 PM   #3
Boondocking,
Thanks for the reply. I will go with the two 12 volt group 31. I'm not sure how much boondocking we will do. I'm trying to get set up so we can give it a try.
Thanks again,
Willie
Old 01-26-2020, 12:23 AM   #4
SlowrideHD's Avatar
Cycling your battery bank down to 20% capacity, even with agm batteries, will significantly shorten your battery life and increase your kwh life cycle cost.
This is a good site to look at for factual battery information.
https://www.solar-electric.com/learn...tery-faq.html/
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is online now   Reply With Quote
Old 01-26-2020, 12:47 AM   #5
Totally agree. There really isn't much difference in the cycle life of AGM and FLA with a 50% discharge. That being said the Peukert's constant of an AGM battery is much lower than a FLA so if you have high current draws, the same amount of current draw on an FLA, will cause your SOC to go much lower on the FLA vs an AGM.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is online now   Reply With Quote
Old 01-26-2020, 01:30 AM   #6
If you want some real factual information about the 80% AGM discharge instead of hearsay, go to the site below.
https://batteryuniversity.com/learn/..._glass_mat_agm
2007 Surveyor SV230
Old 01-26-2020, 11:10 AM   #7
Or if you want some REAL information just go on the Trojan site. They have the discharge vs cycles charts on THEIR AGM and FLA batteries, instead of the hearsay on the Battery university site. You will see they are close for 50% discharge and 80% discharge. You lose a lot of cycles going from 50% to 80% for either battery.
Don't get me wrong, I prefer AGM over FLA for a number of reasons. Just don't believe that you should regularly discharge AGM to 80%.
battery
