Originally Posted by TitanMike
Does it have an Isolation Solenoid that only connects therm when you turn on the key and disconnects them from the parallel circuit when you turn it off?
If not then hope you don't have one of those batteries develop a bad cell that lowers it's voltage. You will end up with two dead batteries.
BTW, I've never heard of a lot of things. Doesn't mean they don't exist.
No there is no Isolation solenoid.
It was built this way, I did not add a second battery, all Dodges with Cummins Diesel have dual battery setup.
Yes, I totally agree with you 100%, if one battery goes bad it can drain the good one, since they are the same age if one is going bad then the other is right behind.
The one time it happened in my Dodge in the past 10 years, it was never dead just low voltage, hard starting BUT never totally dead! The bad battery will only drag the other down to what the bad battery voltage can hold, so one cell goes bad it still will have 10.5 volts in a battery! All the cells would have to go bad for a battery to drain to zero volts. It is rare that a cell would totally fail, get weak yes!
For the past 30 plus years of owning, Travel Trailer, Motor Homes, and several 5th wheels, ALL have had dual parallel battery setup.
I have never had less than 5 year old batteries do what you have described, except when one goes bad... but the first sign of a problem is quick voltage drop when you pull a heavy load, like the water pump or the heater! When that happens time for new batteries!
But I always replace both NEVER one!
As stated my Dodge and 5th wheel have Dual parallel battery setup that sets 3 months, the 5th wheel could sit for 6 months, never had dead batteries. The 5th wheel all I do is turn the disconnect off but the batteries are still connected parallel. maybe 12.5 after 6 months, but it all depends on how cold batteries get, if they get cold, then they can drain a little!
