09-24-2017, 09:03 PM
Another electrical quandry...
09-24-2017, 09:13 PM
Location: Alberta - East of the Rockies, West of the Rest
Have you inspected the Ground and Neutral connections?
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
09-24-2017, 09:28 PM
I haven't, but all the lights on the ESP were displaying correctly with no indication of fault.
09-24-2017, 09:50 PM
Came home, plugged into my 30 amp shore power, flipped breakers on...Nothing
assume that you just came from a campground, plugged into pedestal and everything worked fine... then you came home and plugged into a HOME-WIRED 30AMP receptacle?
Correct so far?
So how do you know that the HOME-WIRED plug is wired correctly?
Have you ever used this shore power at home before?
How about you give us a model and year of your RV...
2014 Shamrock 183
09-24-2017, 11:35 PM
I've used the same receptacle for 2 years.
09-24-2017, 11:36 PM
It is a 2016 Wildwood 28DBUD
09-25-2017, 01:00 AM
Define 'nothing'. On the AC side there are typically a few separate circuits, the GFCI protected outlets being one of them. The microwave and fridge are often on their own circuits. You may want to disable all AC branch circuits via the breakers and turn them on one by one, if they don't work you need to look upstream of the converter/power distribution box.
09-25-2017, 03:01 AM
Try FOX instead of ESP! Youroo!!
09-25-2017, 07:04 AM
Nothing, meaning no power through GFCI or through main or any other breakers when ESP is plugged in, but the three green lights are all on. I plugged a fan into a GFCI plug, to be sure.
09-25-2017, 07:05 AM
All circuits were turned on one by one, starting with the main.
