05-23-2022, 08:41 PM
Any problems with using 2 separate solar controllers?
Hi everyone.
Recently bought an Alta with a 50 watt system preinstalled. Don't want to invest the money yet to upgrade it. I also own a thunderbolt 100 watt system. Can I hook the thunderbolt controller directly to my battery while the preinstalled controller is also attached? (It's a Waaree pwm controller)
Anyone know if this is this acceptable, or will it cause problems with my battery (or either controller)
Thanks for any input.
Steve
05-23-2022, 09:27 PM
No problem. Send it.
2019 F150 HDPP 4X4 3.5. 2500lb payload.
2018 Rockwood 2506
05-23-2022, 10:46 PM
Originally Posted by srockhill
Hi everyone.
Steve
I have the onboard 50watt panel with the pwm and I also connect 220w with a victron controller with no issues.
05-23-2022, 11:49 PM
Hi everyone.
Steve
It's effective and harmless.
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
05-24-2022, 05:08 AM
Just get the settings between both controller’s the same or close to the same.
As the charge voltage, and float voltage.
2015 silverback 31IK
2023 f350
05-24-2022, 03:15 PM
That doesn't sound like any problem to me at all. I remember the first time a friend of mine suggested strapping a standard 25 amp battery charger to my battery bank while charging from shore power. The concept almost gave me a heart attack but when I checked it out it wasn't a problem at all and it doubled my charging rate. Same thing seems to work with solar. A lot of folks report using roof mount system supplemented by a portable system and I've never heard of a problem.
Tom48
In Sunny So Cal /w
Now in 2005 Holiday Rambler Ambassador DP and The Hot Air Balloon RESTLESS
NO MORE Tricked out
2017 Sandstorm 250 T.H.
05-24-2022, 03:51 PM
Using multiple charging sources, solar, Converter, Battery Charger, etc is no different than filling a swimming pool by using several hoses of different sizes and at different pressures. The pool fills more quickly.
Even if the hoses are connected to a closed container as the internal pressure (in this case a battery) reaches the same pressure as the lowest hose pressure, flow from that source will cease and same for remaining hoses.
The only caveat is that if one has different sized solar panels, each panel or combination of panels will require their own controller but their outputs can all be connected to the same battery.
The oft stated warning "the different sources will fight each other and cause problems" is totally false and just based on total lack of knowledge of how electricity works.
05-25-2022, 06:33 AM
In fact, from what I've read, it is recommended to have separate charge controllers. Works better if one panel is shaded and the other isn't.
05-25-2022, 08:45 AM
If wired in parallel, not a concern. In series there will be loss if one is shaded as you get a drop from the diodes.
2018 Rockwood 2506
