Bad Converter? Low voltage.
So it looks like my converter went bad. Before I get a new one, I thought I'd check here to make sure I didn't miss something.I inadvertently forgot to plug in my trailer when I got home from a weekend so in a couple days of course My battery went dead.
When I did plug in, I noticed the battery wouldn't charge so I checked the reverse polarity fuses, re-settable breaker on the frame, etc. All are good.
In addition, I was able to charge the battery just fine with an external charger after turning off the disconnect.
With the battery charged and the trailer unplugged from 120v, everything works fine, so I know I don't have a bad connection or a hidden fuse or breaker I missed.
HOWEVER, after 24 hours, the battery was draining again so I checked the output of the converter and it's only 11.4V.
I would expect it to be 13.7v if good or zero if it went bad, but not low.
By the way, this is a WF-8955. I'm surprised that killing the battery once in two seasons would kill a converter like that. I'm guessing a regulator chip went bad.
Thanks!
Ray
2017 Rockwood 2109S
Ram 1500
Me Her And a furry little dog
US Navy Veteran
