Old 07-14-2017, 08:26 AM   #1
Wolverine 1945's Avatar
Batteries Gave Out/Up
I need to do some searching as soon as I get time,,, I am pretty sure we need new batteries,,, We were boondocking Sunday night,,, only thing we had on was the TV,,, and it went off after just over an hour,,, Batteries were so weak the Fridge quit working ???
Crazy thing is our battery monitor has been saying Full Charge all along !!! LIAR !!!
Wolverine 1945 is online now   Reply With Quote
Old 07-14-2017, 08:38 AM   #2
The battery monitor lights are as worthless as the tank monitor lights.
I can't believe manufacturers are still using them as they are pretty much totally worthless for either system.
Also if you are plugged into shore power, the battery monitor lights WILL say full charged because it is reading the converter voltage not the battery.
Days Camped: '18=51 '19=58 '20=110 '21=94
Old 07-14-2017, 08:46 AM   #3
Oakman's Avatar
Anytime you are plugged in to a power pedestal at a campground the battery will register full unless it is a completely dead battery. Even then I’m not sure the monitor wouldn’t show a full charge because the converter/charger is working when plugged into power. The time to check the battery monitor is without a 120v source hooked up to the RV.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 07-15-2017, 07:08 AM   #4
Right on picker & Oakman !!!
I am going to start by unhooking the Batteries and trying to test them,,, I believe 1 or both are Bad ??? Monitor has always worked pretty good in the past,,, but has read full ever since winter,,, even after a couple of months of being unhooked it read full,,, I am thinking maybe after unhooking it will reset ???
I will be checking it out in a couple of days !!!
What brand of 12v Deep Cell Batteries do you guys think is best ???
Only batteries I have bought in years is Motorcraft,,, Great Batteries !!!
But I am guessing they do not sell RV batteries ???
Sorry I did not mean to hijack the thread !!!
Old 07-15-2017, 09:21 AM   #5
camaraderie's Avatar
Wait 24 hours AFTER you unhook them to get a true voltage reading at the terminals of each battery. Anything less than 12.4V means loss of capacity...but still OK for limited "off plug" use. Anything less than 12.2 means less than 50% capacity and time to replace.
If you RARELY if ever camp without electricity...save your money and head to Walmart for Everstart deep cycle/marine dual purpose batteries cause you don't NEED real deep cycles since you never DO deep cycle. (Like me!). If you DO boondock...then a pair of Trojan deep cycles is an excellent value on a cost per amp delivered over the lifetime. Deka also makes a good TRUE deep cycle...look for DC in the model number.
Motorcrart does not make batteries...they buy from others and relable. Johnson Controls which makes for Motorcraft currently also makes for Walmart.
________
Cam
2015 Georgetown 280DS
camaraderie is offline   Reply With Quote
Old 07-15-2017, 09:28 AM   #6
Thank You Very Much Cam !!!
I will check Walmart,,, and the EverStart !!!
We probably only Boondock 1 day a year !!!
Old 07-16-2017, 06:10 AM   #7
DW went to Harbor Fright yesterday and got me a Load Battery Tester for $22- 20%,,, my plan today is to unplug the MH,,, turn Battery switch off,,, unhook each Battery and test them !!! I did find that our Walmarts here sell a 24V RV Battery,,, Evert Start for $75 Probably good enough for us ???
Old 07-16-2017, 06:15 AM   #8
SYE
SYE's Avatar
A 24 volt battery will be very bad if you use it, all of the items in your camper are designed for 12v, 24 v will probably damage these items, and now your 100 dollar battery is 1000 or more in repairs
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
SYE is offline   Reply With Quote
Old 07-16-2017, 06:17 AM   #9
KyDan's Avatar
24v RV battery???
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-41
Old 07-16-2017, 06:19 AM   #10
Very True,,, My mistake it is a 12v Battery Model# is 24DC !!!
Old 07-16-2017, 06:20 AM   #11
SYE
SYE's Avatar
That's better
Scott & Vicki
2021 4 reserved
Old 07-16-2017, 06:26 AM   #12
That's better
Right On !!!
Maybe I need more Coffee ???
LOL !!!
Old 07-16-2017, 07:22 AM   #13
Walmart does not sell 24v batteries....I think he means a GRoup.24 sized battery which will be fine... the but it took me by surprise for a few seconds too!.
Old 07-16-2017, 07:32 AM   #14
Just checking to see if you guys are on your toes !!! LOL !!!
I do need to check the size of these 24DCs,,, web page does not show the size ???
Old 07-16-2017, 07:43 AM   #15
That's 10.75 x6.75 x9.37.... inches ...not meters!
________
Cam
Old 07-16-2017, 07:52 AM   #16
I hate Meters,,, to old to understand any of that Metric Crap !!!
That is about what I found,,, length - 10.25 Width - 6 13/16 Height - 8 7/8 !!!
I will have to check the size of what I have,,, time to get after it !!!
I see Walmart has a Everstart Max,,, for $100 ???
Feedback on the $75 one is not Great ???
Thanks for all your Info !!!
Old 07-16-2017, 08:00 AM   #17
Get the largest size that will fit the space you have in the MarineDC everstart line. The Maxx batteries are starting batteries. Group 27 or 31 have more amp hours than group 24 for that one night a year when you need them!
Good luck!
________
Cam
Old 07-16-2017, 08:05 AM   #18
Good luck!
Right On Cam,,, I think my Batteries just maybe larger than the 24DC,,,
Will know soon !!! I will get back tomorrow !!!
Old 07-17-2017, 06:17 AM   #19
Originally Posted by rockfordroo View Post
You might want to read the attached document, The 12 Volt Side of Life, before you go any further.
Great Info !!!
Old 07-17-2017, 07:51 AM   #20
I belive Batteries must be Group 27,,, they are about 12" long !!!
They test our very good ??? Maybe they are not being recharged while we are driving ???
