Old 07-07-2020, 02:14 PM   #1
Batteries not charging with shore power
Hi,
I have my 2017 Sunseeker plugged into my home power. The cord lights up with blue light to show the electric cord to the motorhome is working. However, there is no electricity to the house -- lights and AC not working. With generator on, I can get both to work. I checked circuit under bed and nothing is tripped. What am I dealing with? Thanks!
SilasMarie is offline   Reply With Quote
Old 07-07-2020, 03:35 PM   #2
Do you have a transfer switch or a generator outlet? If a transfer switch, give it a wrap with something to see if it is stuck. If a generator outlet, the problem is your home outlet
ScottBrownstein is offline   Reply With Quote
Old 07-07-2020, 04:01 PM   #3
So it appears that things work if you get 120 volts out of the transfer switch. So the problem must be in the power path from the receptacle you are plugged into and the transfer switch output. Possible point of failure include:
The receptacle
The shore power cord
The shore power cord reel if you have one
The sore power connection into the RV
An EMS device in the shore power path
The transfer switch
Any adapters you are using
Use your multimeter to test for each and every connection from the receptacle up to the transfer switch. Verify that you have proper voltage at each connection!
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 07-07-2020, 04:15 PM   #4
Just as confused as you
Scrapper's Avatar
How are you plugged into your home power? If you are plugged into a 15/20 amp GFCI outlet on your house with an adapter on your power cord the house GFCI could be tripped. The rv has GFCI outlets in it and being plugged into one at the house will cause the house GFCI to trip. GFCI's do not ply well together.
Richard & Jill
batteries, charging, power, shore power
