Old 03-03-2020, 03:08 PM   #1
Battery Capacity Monitor
I just finished installing the battery monitor to keep track of the exterior 12v battery. Install included extending the shielded wire and mounting the shunt in a box mounted to the side of the battery case. I just completed testing and everything works as it should. This is the relatively inexpensive unit made in China. Overall I think it is a good value for the $. Now as far as durability, only time will tell.
RDW
RogerWo is offline   Reply With Quote
Old 03-03-2020, 06:01 PM   #2
These inexpensive monitors that just measure voltage and current in/out of the battery are pretty durable. Super simple so not much to go wrong.
Where they come up short is in the accuracy of their CAPACITY or State Of Charge calculations. Lead Acid batteries have inefficiencies that require the use of a more complex meter to accurately measure SOC.
The inexpensive units are better than just the LED units but nowhere near that of the Victron type units. If you "work off the top" of your battery charge they may be good enough. However if you need more of your battery the indication from the cheaper meters may leave you thinking you have more battery left than you do. That can make for some cold mornings when the furnace is out of power
"A wise man can change his mind. A fool never will."
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
Old 03-03-2020, 06:05 PM   #3
Trailer Park Supervisor
NJKris's Avatar
I was looking at some of the China special monitors on Amazon, pretty good for 30 bucks, but I noticed from comments that current in and current out are totaled, no way to see either by themselves. In that case, a simple voltmeter/percentage is about the same. I think it's worth a few extra bucks to see current in, current out.
NJKris is offline   Reply With Quote
Old 03-03-2020, 06:20 PM   #4
The issue with these meters is that it's not as simple as current in, current out, with a lead acid battery. The faster you draw current out or put current in (charge) the more inaccurate they become for determining the actual SOC of the battery. It's all due to the "Lag" in the chemical reaction in the battery and thus the need for a monitor that can utilize the Peukert Factor in it's calculations. THAT is what adds to the cost.
Also, Lead Acid batteries are slaves to temperature. Temperature correction becomes a factor as well and ideally the monitor has a temperature sensor as well.
If one wants to do all the calculations in their head (good luck) or on paper (I'd rather do a crossword puzzle) then a simple meter is probably OK. That said, if it's essential that one know how much power they are using and how long it will last, then spring for the better meter. You only have to buy it once and it may even allow your battery bank to last a few years longer.
2004 Nissan Titan
Old 03-03-2020, 10:02 PM   #5
Had a guy send me some videos of his cheap chinese amazon monitor to try and troubleshoot. Went through all the trouble of wiring up his shunt and found that the thing would oscillate between a bunch of current readings that didn't make any sense. He is now waiting for the Victron Smart shunt to come out.
The one he bought was this piece of junk
https://www.amazon.com/Voltmeter-Amm...b_b_asin_title
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
battery
