Originally Posted by FollowTheSun
Hi CnJ88,
As jd4010 stated: “leave them connected and charge them as a single 12v battery.”
Flooded lead acid batteries are made by connecting a series of ≈2.12-volt cells in series. Thus, 3 cells X 2.12 volts ≈ 6.4 volts; 6 cells X 2.12 ≈ 12.7 volts. Your observation that charging voltage sometimes exceeds 14 volts is normal during the bulk phase of the charging cycle. I suspect that the NOCO Genius Battery Charger Maintainer provides, at least, the following three basic modes while charging (12-volt) batteries:
- Bulk Charge 14.4v – 14.7v (constant current, increasing voltage)
- Absorption Charge 14.4v – 14.7v (reducing current, constant voltage)
- Maintenance Charge 13.4v – 13.8v (constant voltage, low current)
The charger might also provide:
- Equalization Charge 15.6v – 16.2v (high voltage, low current)
Factoid: I just purchased a BatteryMinder Plus model 1510 to charge/maintain the RV house batteries. In the back of the manual it shows three common multiple battery configurations: two 12 volt batteries in parallel; two six volt batteries in series; and, four six volt batteries in series-parallel. Each configuration has 12 volt output. Also, each configuration shows where to connect the BatteryMinder Charger.
Thank you for the great info and thank jd4010 for the great advice. I put both to good use.
