Hi Folks, could use some help with a charging issue. I bought a 2015 Forester MBS 2401S from my local dealer near end of this past summer. Had a few 4/5 night trips with it and was noticing my battery monitor never showed house batteries ( 2 Optima Blue D34M AGMs ) fully charged even though I was plugged into shore power most of time?
The dealer had given me a "30 day warranty" on everything working ok so I went back to them with a short list including my questioning if charging system is working correctly. They checked charging system and identified issue with BIM ( battery isolator manager ? ). Currently waiting for part to come in ( now 10 weeks and counting ) but that is another issue :-(.
In mean time, I read the following on function of BIM: connects 2 battery systems together during charging. Coach batteries charged while driving and chassis battery charged while plugged into shore power ( I assume while generator is running as well ).
So it make sense to me about the house batteries not being charged by the MBS alternator as I while waiting for the part I have taken my RV for a 25 minute drive from the dealer lot and did not see evidence of house batteries being charged ( using my new voltmeter instead of just control panel monitor ) but I question I do not have an additional issue with my batteries?
The reason being I have twice first checked the voltage on my batteries at being about 11.7 V , run my generator for about 45 - 60 min with reading then at about 12.2 ( knowing that is a false reading right after charging ) and then next time I run my test within week or two I see voltage of batteries back at about 11.7 ( 1/3 full based on control panel )
. I have made sure the battery disconnect switch was turned off when leaving the RV. Also confirmed voltmeter showing 14.2 V while generator running.
What I am hoping someone could confirm for me that if this does sound more than just a BIM issue? I assume the dealer should be able to confirm the state of my batteries too ( if they have not already done so ) but was hoping to get someone's opinion before I try to talk to the technician who diagnosed the issue ( service desk person does not seem to be familar with the issue ). Would appreciate any input. Thx.
Note: I have also read on this forum that my 2 Optima Blue D34Ms are not true deep cycle batteries so I had planned to replace them eventually but just wanted to understand if I should do that sooner than later.
