Not sure I understand. Solar systems should not DRAW power from the batteries when there is no sunlight. Diodes in Controller and Panels prevent the flow of current from the batteries, and allow current to flow INTO the batteries when producing power from the sun.
When you refer to "Go Power" not having a low voltage shutoff, are you possibly referring to an Inverter?
I know that the solar controller I use can be left on 24/7/365 (Victron Smart MPPT) and it only puts power into the batteries. Usually it's the inverter that has to shut off when power runs low. If it doesn't have one built in the only solution would be to replace it with one that does or install a battery isolation device that has the LV shutoff.
Of course another solution could be "more battery capacity".
