10-28-2021, 01:14 PM
Battery Disconnect
Hey guys, this might be silly but I am racking my brain. With the battery disconnect in the ON position and hooked up to shore power, I noticed my battery run all the way below 3v. I would even throw a B01 error on the panel. I went outside, threw the battery disconnect to the OFF position, and I havent had a problem since.
My main question here is this: If the battery disconnect is in the ON position - this means my batteries are disconnected and when the switch is in the OFF position it means my batteries ARE connected, right?
Im just trying to figure out why my battery would drain when hooked to shore power.
'21 CC Champagne 38EKS
'21 Ram 3500 DRW 4x4
10-28-2021, 01:21 PM
That is correct. On means disconnected in most cases.
2020 GMC Denali 4X4 2500HD Duramax
2018 Work & Play 25WAB
10-28-2021, 03:23 PM
When you engaged the disconnect switch, by turning it on, you took the batteries out of the charging circuit.
Only engage the disconnect switch when it's not connected to shore power, so the parasitic power drains won't deplete the batteries.
10-28-2021, 04:43 PM
Uhhh, here is what Forest River Inc, states about their battery disconnect switches, via videos. It does not seem to agree with the previous advice.
https://www.forestriverforums.com/fo...ff-217978.html
2011 Flagstaff 831 RLBSS
10-28-2021, 04:49 PM
This can be caused by a bad converter, or you have blown the reverse polarity fuses to the converter. Please read posts #1,2, and #5 in this thread:
https://www.forestriverforums.com/fo...nt-152813.html
Have you checked to make sure the battery is good?
10-28-2021, 05:31 PM
This is one of my pet peeves. They should never label the "Battery Disconnect" On or Off, all disconnects should be labeled Open and Closed. That would cut down on a lot of confusion.
Having said that, all the Disconnects I've seen on RV's have been as the links that Wmtire posted, On means that the battery is connected and Off means that the battery is disconnected.
Gotta go campin!
10-28-2021, 05:46 PM
If the switch is labelled "battery Disconnect" then ON would be in compliance for the switch function which would mean the batteries are disconnected. The switch should just be labelled "batteries" then ON would comply with the switch function which would mean the batteries are connected. The label for a switch should denote its intended function. If the switch is labelled as said and the function is the opposite then it is ambiguous to say the least and totally misleading.
10-28-2021, 05:55 PM
This is why we made the FAQ showing the Forest River videos on this subject matter. It does get confusing.
10-31-2021, 11:08 PM
Georgetown GT5 31R5
The battery disconnect/connect switch on my RV contains a light bulb that is illuminated when switched on (batteries connected) and off when switch is in off position (batteries disconnected). However it is misleading that the coach batteries are disconnected, they are mostly disconnected. Because there are 3 wires that bypass this main disconnect switch and are directly connected to the positive terminal of one of the coach batteries. This results in parasitic losses not prevented by switch. So, I recently installed a disconnect switch in the ground cable to ensure complete isolation.
Go Poly
2019 Georgetown GT5 31R5
11-01-2021, 12:59 AM
A $7 voltmeter from Harbor Freight would remove all doubts.
11-01-2021, 09:54 AM
No doubts…
…that’s why I wired in a ground isolation switch.
Go Poly
11-01-2021, 10:00 AM
Originally Posted by wmtire
Ill check that all out - I hope not - the trailer is brand new lol
11-01-2021, 10:06 AM
Yeah, their advice for the 'key type' is to just cover the DISCONNECT word. ON means batteries are connected, OFF means they are not connected.
Will check out the other options you suggested as I should not run a battery down on the ON position
11-01-2021, 10:11 AM
Does your coach have this installed?
11-01-2021, 10:12 AM
Yes you should not run a battery down IF your shore power connection is good (you are getting 120 volt AC to the electric distribution panel in the RV) ....AND the converter is outputting
You need to make sure you have 120 volt AC inside the RV for the converter to work. Are your microwave lights on or operational?
11-01-2021, 10:32 AM
Yes, similar to that. But as I said, not all devices are routed through that box/main disconnect switch.
Go Poly
11-01-2021, 10:53 AM
Found the issue - Im an idiot. I was reading the switch key in the wrong way. Short side of the key points to the way the switch orientation says.
Quick tip for anyone else, if you cannot remove the key for the switch, it is ON. If you can remove the key from the switch, it is in the OFF position.
So turned out I had the coach in the OFF position the first couple days of camping. Thinking I turned it OFF (but actually turning it ON) is why everything all of a sudden became right in the world.
11-01-2021, 11:01 AM
That is correct but you could just have moved those items from the battery post to the #1 post on the side of the BCC. Those items do include the awning/steps and possibly the LP detector and evidently those items having power with batteries disconnected are not important. The BCC #1 stud is only powered when the battery disconnect switch is ON and/or when shore power is applied. This is predicated upon an SDC-107 type BCC installed. Oh well.
11-01-2021, 11:10 AM
Thanks!
Thank you Bubbles! I appreciate any knowledge to help me navigate the nuances of this M/H! My previous M/H I always found myself battling battery issues! This M/H has been challenging as well.
Go Poly
11-01-2021, 12:28 PM
Glad you found it was simply user error.
On another note I see there are several conversations going in this thread with a motorhome being thrown in the mix which can be confusing things.
You stated you have a travel trailer thus do not have a motorhome coach.
