Old 02-25-2023, 11:35 PM   #21
I was in the process of moving the top wire to the bottom terminal, since the battery switch was not working
Chrisjan84 is offline   Reply With Quote
Old 02-25-2023, 11:40 PM   #22
JimM2109S's Avatar
If the center of the pic is of the disconnect switch, the two wires marked with a question mark most probably are power to an onboard inverter and the other to your 12v distribution panel. The latter will serve double duty to charge your battery from the converter.
2022 MiniLite 2109s
2018 F-150 XLT 4x4, 3.5L, Max tow pkg
2019 Ranger Lariat 4x4 (in reserve)
(We're just getting started!)
JimM2109S is offline   Reply With Quote
battery, battery disconnect
