Old 03-02-2024, 09:00 AM   #1
Battery disconnect replacement
I have a broken battery disconnect knob. As in the pull knob got broken off by my 2 year old lol its connected and not giving me issues. But still need to replace.
I got a replacement knob, just curious if I can replace it I I'm careful with the wires, or should I just disconnect my battery terminals, then replace the disconnect switch?
Thanks in advance
Devin C is offline   Reply With Quote
Old 03-02-2024, 09:42 AM   #2
Old guy having fun
Believer45's Avatar
Thanks in advance
I would suggest disconnecting the battery. It is very easy for a loose cable to get against a ground point while doing something like this.
2013 Forest River Windjammer 3008W
2011 Ram 2500 crew cab short bed diesel 6 speed auto 3.73 gears RWD
Believer45 is offline   Reply With Quote
Old 03-02-2024, 09:46 PM   #3
And make sure you are unplugged from shore power so the line from any converter/changer/inverter is not live.
MGD1961 is offline   Reply With Quote
Old 03-02-2024, 09:53 PM   #4
And disconnect solar charging wires.
NavyLCDR is offline   Reply With Quote
Old 03-03-2024, 09:23 AM   #5
while you are under there
check all the other connections
especially the negative to frame....
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 03-03-2024, 10:43 AM   #6
Thanks everyone. I unplugged all power, even switched off all breakers just incase. Switched the battery disconnect out for the new one. All went well �� thanks again for the advice.
Old 03-03-2024, 06:10 PM   #7
Old guy having fun
Believer45's Avatar
Glad it went without a hitch. We all like when that happens!
Old 03-03-2024, 06:23 PM   #8
Chuck_S's Avatar
Ahhh, you didn't replace the knob you replaced the entire switch. Your first post confused me as there's no reason to disconnect anything to replace the knob.
-- Chuck
Chuck_S is offline   Reply With Quote
battery, battery disconnect, replacement
