Old 04-18-2016, 12:40 PM   #1
Battery disconnect switch
I discovered the battery disconnect switch on my 2016 Sierra 371 REBH is not working. The switch is off (battery disconnected) however, I still have power to all 12 volt applications (lights, electric jacks, etc.)
Thinking it was a bad switch, I removed one of the power cables connected to the back of the switch and still have power to all 12 volt applications.
Of course, this is draining my battery.
Amy help is appreciated.
Rdsmith281 is offline   Reply With Quote
Old 04-18-2016, 12:55 PM   #2
TURBS's Avatar
Are you plugged in during this test?
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
Old 04-18-2016, 12:55 PM   #3
Sounds like you are connected to shore power and running off the converter. If you are plugged in then unplug and check disconnect switch again.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre - Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
Old 04-18-2016, 12:56 PM   #4
TURBS's Avatar
My thoughts exactly!
Old 04-18-2016, 01:57 PM   #5
Not plugged in.
Not plugged in. Running on battery only.
Old 04-18-2016, 02:13 PM   #6
TURBS's Avatar
How many wires are hooked to the positive battery post?
2008 2500hd Duramax
2015 Columbus 320RS
Old 04-18-2016, 04:28 PM   #7
Here's a pic of the batteries.
Old 04-18-2016, 07:42 PM   #8
Is the disconnect switch connected to the cable that is tagged "inve" ?
2007 Surveyor SV230
Old 04-18-2016, 08:52 PM   #9
Not sure. it's difficult to trace since the disconnect switch and the battery are on opposite sides of the 5er. I just know that the disconnect has two red battery cables.
Old 04-18-2016, 09:06 PM   #10
Canadian Member
You seem to have 2 positive wires and 2 negative wires leaving the batteries. One set is probably going to the inverter (the ones with the yellowish connectors). Does the inverter feed the converter including the 12v side?
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
Old 04-18-2016, 11:16 PM   #11
I have a hunch that the disconnect switch only turns off the inverter. Turn off the disconnect and see if the fridge light goes out.
2007 Surveyor SV230
Old 04-20-2016, 12:36 PM   #12
I really don't know.
Old 04-20-2016, 12:49 PM   #13
Turn off the disconnect and check the fridge light. If the fridge light is not on then the disconnect is just for the inverter and not the whole trailer.
2007 Surveyor SV230
Old 04-20-2016, 12:55 PM   #14
Should the fridge light be on? I'm not plugged in.
Old 04-20-2016, 12:57 PM   #15
TURBS's Avatar
Yes it's running on the battery.
Old 04-20-2016, 01:04 PM   #16
Ok, I'll check it out.
Thanks for the quick response.
If I determine the disconnect switch is for the inverter only, is this normal? I was under the impression that the disconnect switch turns off all 12 volt applications.
Old 04-20-2016, 01:05 PM   #17
TURBS's Avatar
If it is I'd add another for other battery.
2008 2500hd Duramax
2015 Columbus 320RS
Old 04-20-2016, 01:40 PM   #18
Thanks for everyone's responses.
Old 04-20-2016, 02:23 PM   #19
You're welcome !
Let us know what you discover.
2007 Surveyor SV230
Old 04-20-2016, 08:59 PM   #20
I discovered it goes to the inverter, just as you mentioned. Thanks. i'm definitely going to install a disconnect switch to the other battery. Thanks again.
battery, battery disconnect
