Originally Posted by CampinGpa
I have a house cut off switch in the water bay. when it is off I still have a drain on the batteries. I would like to put a battery cutoff switch on. I have two 12 volt batteries. Do I have to buy two cutoff switches one for each battery. So I can eliminate removing the negative cable and drain on the batteries when in storage. Thank you in advance
Gramps, the two batteries are connected in parallel. That means the two Positive (red) terminals are connected together and the two negative (black) terminals are connected together.
You can use a single disconnect switch by identifying the negative terminal that has two cables: one to the other battery and one to the motorhome.
On that terminal, remove the cable going to the motorhome.
Leave the cable going to the other battery, and add the disconnect switch.
Connect the cable going to the motorhome to the other end of the disconnect switch.
I will flag these posts so the moderator moves them to the right place.
