Old 08-21-2024, 12:00 PM   #1
Battery Disconnect switch knob broke
I have 2023 Geo Pro 19FDS, and the battery disconnect switch broke while turning it. Does any one knows the replacement part number or something compatible?
Thanks in Advance!
Zigman
Zygmunt is offline   Reply With Quote
Old 08-21-2024, 12:14 PM   #2
My "Flag style" only lasted 2 years
so I bought a "Marine grade" disconnect and moved it inside the pass through... out of the rain
https://www.google.com/search?client...ery+disconnect
PS left the original in place so the little kiddies in the campground can giggle all they want!
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 08-21-2024, 12:20 PM   #3
Thanks for the reply. Would you recommend an "Upgrade Battery Disconnect Switch with Voltmeter"?
Thanks!
Old 08-21-2024, 12:20 PM   #4
wmtire's Avatar
Thanks in Advance!
Zigman
A pic of this would help tremendously, as not every RV has the same switch depending on availability at time of manufacture.
2011 Flagstaff 831 RLBSS
Sometimes I wonder why I'm not in an asylum. Then I take a good look around at everyone and realize...Maybe I am.
Old 08-21-2024, 12:24 PM   #5
Hello,
I am not near the RV today. I am planning on going camping next Monday, but don't have chance to get to it until weekend and I would like to replace it on Sunday before the trip on Monday.
Old 08-21-2024, 12:30 PM   #6
worse case if you cant replace it in time...
just move the wires to be on the same terminal of the faulty switch
make Notes so you won't forget what wires you moved
You should be able to pickup a switch from a lot of local automotive stores marine stores or even hardware
Tarpon Springs FL
2022 Salem 24RLXL
Old 08-21-2024, 12:33 PM   #7
Thanks! I already took the battery out to re-charge it before the trip. The RV is in under cover storage. I would like to replace it before the trip. Do you think a Battery Disconnect Switch with Voltmeter is a good idea? I am curious if it would drain the battery when not using it over the winter.
Thanks!
Old 08-21-2024, 12:34 PM   #8
PhilFromMaine's Avatar
Thanks!
It depends on the quality of the disconnect switch. As Aussie said, true Marine quality is the best. However, will pay approximately twice as much. Look at Blue Sea products. Having a voltage display is also a nice feature. IMO, you can't have enough of them.
2018 Coachmen Freedom Express Liberty Edition 231RBDSLE
PhilFromMaine is online now   Reply With Quote
Old 08-21-2024, 12:36 PM   #9
Thanks! Like my Mom stated , buy it once and buy it right. It isn't worth getting something cheap.
Old 08-21-2024, 12:41 PM   #10
if you ever decide to go lithium voltage is not so much of a great indicator
Is the switch in a place you can easily see?
would not be hard to add a volt meter inside near your switch panel so you'll see it better?
OR... If you really want a good meter you can get a $60 shunt and it will keep better track of your battery usage...
Tarpon Springs FL
2022 Salem 24RLXL
Old 08-21-2024, 12:49 PM   #11
Doesn't matter
It doesn't matter which wire goes where on a 2-wire switch. When you get the new one, just make sure one wire goes on each terminal.
Larry
Larry-NC is offline   Reply With Quote
Old 08-21-2024, 12:57 PM   #12
mine had 3 wires
Tarpon Springs FL
2022 Salem 24RLXL
Old 08-21-2024, 01:04 PM   #13
Probably for battery A and battery B.
Capacitor is offline   Reply With Quote
Old 08-21-2024, 01:16 PM   #14
never bothered to track where the second smaller wire went
just connected it to the same wire it was on... tied them together with zip ties
Other wire went to battery
Tarpon Springs FL
2022 Salem 24RLXL
Old 08-21-2024, 02:25 PM   #15
It may go to the tongue jack. The disconnect with three lugs is usually for battery a,b and both. Should be labeled as such.
Old 08-21-2024, 04:53 PM   #16
In that case...
In that case, you don't care which terminal the small wire is on, since it draws 0 current when the jack switch is off.
Two heavy wires on separate terminals.
The light wire on either terminal.
Larry
Old 08-21-2024, 05:23 PM   #17
Well sort of. Here is the wiring for a three lug switch but really doesn’t answer the op question. Just for info.
Old 08-21-2024, 10:18 PM   #18
SailorSam20500's Avatar
I replaced my switch last year after the key broke. It was a bugger to get the old switch off. After I got the replacement, I realized that the replacements that you can find on both Amazon and Walmart would have worked on the old switch - assuming you find one that looks correct for what you currently have.
Another good source for replacements is your local boat store... They may also have replacement keys.
Personally, I don't think a switch with a voltage level display would be all that valuable.
Have fun on your trip!
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 09-06-2024, 08:33 AM   #19
Harbor Freight has them!
Thanks in Advance!
Zigman
Our switch went bad and had to be replaced. I found the exact same switch at Harbor Freight. It was under $10 and easy to replace (while lying on your back and working upside down) Not placed in the most ideal location.
Lanree is offline   Reply With Quote
battery, battery disconnect, switch
