Originally Posted by JCGHThomas
Thank you all so very much. We will get a voltage meter and check what you all have suggested. I will let you all know how we make out. One last thing, I believe the converter is in behind the fuses, correct? And if so how will we know which is the battery power going in and the DC going out? Thanks again and enjoy the remainder of your day!
Since you're gonna buy a multimeter...go on amazon and get one that has clamps on the end of it to measure BOTH AC and DC current.
They can be had for about 50 bucks on amazon and will let you know a lot of stuff on things working or not and tracing down problems. If you're gonna try to diagnose and fix stuff yourself on the RV...you're gonna need one eventually...so you might as well spring for it up front.
One last thing...tp immediately know something about how your charging system is working. Have the camper plugged in.
Put yout meter leads on the battery - & + and take a voltage reading.
If it reads ANYTHING over 13.2V and less than 15 volts...your charging system is fine. If it doesn't....then you need to start troubleshooting as suggested above. Good luck!
