Old 07-17-2022, 11:43 AM   #1
Battery issues
Recently just purchased a 2009 Georgetown Class A 50amp and I’m coming from a smaller 30amp RV. .
How do you maintain the batteries plugged into shore power?
Currently when I plug in to 110 to allow the batteries to maintain a trickle charge the batteries are not maintaining a charge, all breakers are off except the breaker to the chaise and yet after being plugged in for 2 weeks both the storage batteries are dead and it killed the engine starting battery. What am I doing wrong?
Charlie8511 is offline   Reply With Quote
Old 07-17-2022, 01:11 PM   #2
If the breakers are off, how would the converter get power?
2019 Palomino Solaire 147X
2013 Ford F150
TacomaJoe is online now   Reply With Quote
Old 07-17-2022, 01:40 PM   #3
I don't know about your particular rig, but in general, you have to have the battery disconnect inside the rig 'off' so that the 'house' battery is connected. Then the house battery will be charged and in some cases, the chassis battery will also be charged.
It's possible that those batteries have reached the end of their useful life too.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 07-17-2022, 02:23 PM   #4
Leave the breakers on and the battery disconnect on. Check the battery water level once in a while. If the batteries are healthy there shouldn't be a problem.
Sunseeker16 is offline   Reply With Quote
Old 07-17-2022, 03:11 PM   #5
The person who designed that setup must have worked for Microsoft on the Windows design team. You know where you have to hit "Start" in order to "Shut Down".
Wouldn't it be so much simpler to label the switch "Battery" with ON meaning ON and OFF meaning OFF?
Regardless, Converter's breaker needs to be ON or no charge will occur.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
battery
