Old 10-19-2015, 09:00 AM   #1
moodog's Avatar
Battery on TT dead.
After turning everything off and fridge set on gas only, my battery is dead in the AM after 6 or 8 hours. Does anyone know what might be draining the battery?
Moodog.
moodog is offline   Reply With Quote
Old 10-19-2015, 09:21 AM   #2
Fridge uses battery for the fan, plus CO2 detector, microwave panel, radio panel, TV power light, 12V TV antenna. 6-8 hours is pretty short, though. Are you sure your battery was full when you started?
2007 Rockwood 1640 LTD Popup -- SOLD
2004 Bantam 19 HTT -- SOLD
2015 Coachmen Freedom Express 292BHDS -- SOLD
2013 RAM 2500 CTD
2018 Prime Time Crusader 319RKT
Loraura is offline   Reply With Quote
Old 10-19-2015, 09:31 AM   #3
TURBS's Avatar
The fridge even on propane needs 12v to power it.
Water heater on propane also needs 12v to power it.
As well as all the other things mentioned above.
All your lights are 12v as well.
I'd be load testing your battery if it's older.
There are alot of 12v power consumption item in your camper if it's not plugged in.
Suggest two batteries?
Check your current battery.
TURBS
08 duramax tuned n modded
2015 columbus 320RS
2015 camping "30 nights"
Old 10-19-2015, 09:33 AM   #4
TURBS's Avatar
Microwave panel and tv power light is 110v not 12v .
Altho there are 12v tv's they are not as commen.
TURBS
2015 columbus 320RS
Old 10-19-2015, 09:43 AM   #5
That's what I get for PBC (posting before coffee).
My biggest 12V draw is the stupid radio panel. I pull the fuse on that if I leave the battery connected.
2013 RAM 2500 CTD
Old 10-19-2015, 09:51 AM   #6
TURBS's Avatar
TURBS
2008 duramax
2015 columbus 320RS
2015 camping "31 nights"
Old 10-19-2015, 10:03 AM   #7
Georgia Rally Coordinator
aceinspp's Avatar
TURBS
2015 columbus 320RS
X 2 also if you do not have LED lights they will drain a battery faster than anything else. First thing I did was to install 2 nd battery when I bough mine. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49 days camped 2021-18
aceinspp is online now   Reply With Quote
Old 10-19-2015, 10:06 AM   #8
TURBS's Avatar
I didn't even get my columbus home and installed a second battery.
TURBS
2008 duramax
2015 columbus 320RS
Old 10-19-2015, 11:37 AM   #9
Check Sticky #3 located in the Tech and Repair Forum, Appliances and Electronics section
Henboy is offline   Reply With Quote
Old 10-19-2015, 12:23 PM   #10
Consider a master power off switch at the battery if you can do that. Something like this: http://www.amazon.com/NOCO-ID220S-6V...cut+off+switch
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 10-19-2015, 12:30 PM   #11
TURBS's Avatar
Since he's trying to run his fridge while unhooked from shore power, a master battery disconnect is not going to help.
TURBS
2008 duramax
2015 columbus 320RS
Old 10-19-2015, 12:40 PM   #12
Same thing happened to me with my A frame this cold weekend. I was hooked to a 3000 watt Honda, refrigerator on 110, when all the outlets suddenly died. By morning I had no lights, GFI would not reset, no microwave, no nothing. Took battery to be charged and while it was charging I turned on generator again. Evdrything worked but outlets, but then the GFI would not reset. I thought the generator was supposed to recharge battery.
royboy334 is online now   Reply With Quote
Old 10-19-2015, 12:47 PM   #13
TURBS
2008 duramax
2015 columbus 320RS
Hummm, I missed that, thanks. Actually I have the same problem. I have thought of running a dedicated 12v power line (fused and switched of course) from the battery to the refer. Have not done this yet.
Old 10-19-2015, 12:59 PM   #14
TURBS's Avatar
Good idea!
TURBS
2008 duramax
2015 columbus 320RS
Old 10-19-2015, 01:01 PM   #15
TURBS's Avatar
Generator should unless there's a current limiting circuit breaker open or your converter has a bad fuse or is not working all together.
Start a new thread and we'll see if we can get your issue resolved.
TURBS
2008 duramax
2015 columbus 320RS
Old 10-19-2015, 04:21 PM   #16
Our TV has an antenna signal booster that runs on 12 volts. It has a green light when it is powered. It's only a small current draw but I switch it off when I don't need it.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 10-19-2015, 04:37 PM   #17
Engineer of Crazy Train
ChooChooMan74's Avatar
This happened to someone else. They pulled their electric brake break-away switch accidentally. This will drain a battery fairy quickly.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 10-19-2015, 05:51 PM   #18
Tom48's Avatar
When I didn't own a TT I borrowed from a friend. He stored it and never charged it as he always used hook ups and the truck charging held things together for the drive.
I learned that starting out with ONE battery is wak, with it really low to begin with the truck did a poor job of charging on the two hour trip to my favorite camp and with a few power guzzling incandescent bulbs at night the battery was dead by morning. Then I discovered that running the generator for four hour didn't get me past the next early morning.
Lesson needed TWO NEW BATTERIES fully charged to begin with and. Learn prudent use of lights. Then four hour of generator every other day
If you tell us year and model of your TT many can tell you More.
Tom48 is offline   Reply With Quote
Old 10-19-2015, 07:05 PM   #19
I had a similar experience with my 2000w generator and a hard wired PI 30 amp surge protector. In my case the PI sensed an open ground. The generators have a floating ground. Just a possible issue.
johng4706 is offline   Reply With Quote
Old 10-20-2015, 11:45 AM   #20
Four hours with the generator running? Were you ready to kill yourself afterwards!
Solar baby! You'll feel better!
Kelly
Show Low and Rio Verde, AZ
cuernoverdesolar.wordpress.com
Klipstr is offline   Reply With Quote
battery
