Old 10-16-2020, 09:40 AM   #1
Battery overload
We have just become owners of a Rockwood Signature Ultra Lite 8319SS. The trailer had been flooded by a hurricane. The 12v system works but there is a small device, about the size of my thumb, where the + side of the battery cable is connected to. it looks like an overload. I can't find any wiring diagrams to tell me what size overload it should be. If anyone has any info it would be appreciated, A wiring diagram would be perfect! Thanks
KevKt is offline   Reply With Quote
Old 10-16-2020, 10:08 AM   #2
Wiring diagrams are not available for almost any R/V.
When you say battery overload are you possibly describing a 12v circuit breaker like the one I've posted a photo of?
Some are resettable (small button on side) and some are not.
They come in various amperages to meet the need of your circuit. (20a-30a-etc.)
Welcome to the forum! I see it is your 1st post!
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 10-16-2020, 03:02 PM   #3
Head Rambler
If it's like the device 5Picker posted above (which can be plastic or metal) then the rating is stamped or printed on the side of it.
If it isn't readable most of them are 30 amp or 40 amp. Post a pic of it and we may be able to help.
Gotta go campin!
Old 10-19-2020, 08:52 AM   #4
overloads?
here is a picture obvious replacement due along with new wire terminals not sure if there will be any readable info on them. The power converter is a 55 amp and all DC circuits are 15 amp fuses.
Old 10-19-2020, 09:36 AM   #5
Head Rambler
Guessing from the wire gauges I would guess that they're 30 amp. That's what I'd try first and if they trip regularly for no reason I'd go to 40 amp.
Gotta go campin!
Old 10-19-2020, 11:03 AM   #6
converter fuses
I did just notice two 40 amp fuses on the converter board I think I should match them. Opinions?
Old 10-19-2020, 11:25 AM   #7
SeaDog's Avatar
before you match something make sure what you are connecting to. That wire may be to the slide if you have one its better to buy a new fuse/breaker then replace a motor. Clean the connections on the battery first.
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-19-2020, 11:53 AM   #8
The 40a fuses 'could' be the reverse polarity protection fuses for the battery and if so, you should match the circuit breakers to them if that is where the wiring from those circuit breakers goes.
It is hard for us to 'tell' you what to use when we really don't know how your unit is wired.
Old 10-19-2020, 12:15 PM   #9
KyDan's Avatar
If you can read the gauge size on the wire anywhere.... if it's AWG 10 go with a 30 amp circuit breaker.
If it's AWG 8 go with a 40 amp.
Like others mentioned- Go with a 30 amp resettable and if you find you have to reset it often, try a 40.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-41
Old 10-20-2020, 07:49 AM   #10
interesting the slides don't work
Old 10-24-2020, 11:51 AM   #11
On our 2109s the bottom one with all the wires going to it is the main 40A breaker and the other is a 30A that serves the slide.
Take them off and look for the markings to get the correct amp ratings.
I carry spares for both of ours -
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2019S Mod Thread
https://www.forestriverforums.com/fo...ad-184896.html
2020 Rockwood Mini Lite 2109S
2017 GMC 2500HD Denali 6.6L Duramax
01tundra is offline   Reply With Quote
Old 10-25-2020, 08:37 AM   #12
thanks, I was not able to find any markings on mine, I replaced both with a 30 amp if they trip out i'll swap it out. Good info!
battery
