If you plan on "living on battery power" for anything more than an overnight stop in a rest area or parking lot, do yourself a huge favor and invest in a small, quiet, generator. If you don't plan on running a high current device like the A/C, a small generator from 1800-2200 watts would do fine.
Charging batteries using the converter will use 700 to 1,000 watts. A microwave will need ~1350-1500 Watts.
Lastly, when charging the battery(s) plan on charging them for several hours, depending on how low it got before charging. The "push button battery monitor" may show "full" after an hour or two but go back and check after charging has been shut off for an hour or more to get the REAL story.
Depending on size, a battery that's discharged 50% can take 2-3 hours to reach about 90% state of charge but to get the last 10% into the battery, it can take another 2-3 hours of charging. Again this depends on the size of the battery(s). If you have an 80 amp hour group 24 battery the above should be a good estimate. If you have two of them, twice as long perhaps.
One of he biggest mistakes made is to "short charge" batteries because the factory battery monitor showed "full".
