Balancing...
The cells inside a battery WILL become unbalanced as you use it
that is normal ... you can see it when you use the app.
Balancing will start at defined point and the BMS will handle that... you don't have to do anything except to ensure you battery is charged long enough to finish the charging.
If you rely on solar for charging.... you need enough panels to charge the replace the night before battery discharge. If your panels are small or it's raining turn off some 12v loads ... a COLD fridge can be turned off for a couple of hours , just don't open the doors a lot while OFF.
Generator... and converter
make sure the converter is actually sending good amperage to battery.
The bluetooth BMS will tell you how much charge the battery is getting
If you got a 55amp converter but never see more than 10-15amps getting to the battery then your converter to battery wiring needs attention.
Shorepower and converter
most people on shorepower are hooked up all night... which gives you plenty of time to fully charge and balance
Once you get use to the battery and APP you will feel more confident... you'll see that it is working ...
For Balancing just make sure when battery is 100% and not doing anything the indivdual cells are close to the same voltage. They MAY never get to exactly the same
lots of good info here ----->
https://diysolarforum.com/threads/ok...tteries.13369/
