Originally Posted by Hclarkx
The usual float voltage, 13.6+/-. will charge a lithium fully given enough time. Heck, anything above 13.3V will do the job but may take hundreds of hours.
For an LiFePo4 battery 13.6 volts is technically 100% SOC but there can be as much as 10% cell imbalance according to some. 13.3 volts will only yield about 90% SOC.
As for cell balance, if one is able to fairly regularly charge Battleborn batteries to 14.6 V using either a DC-DC Charger like the Renogy units, a battery charger/maintainer like those from CTEK, NOCO, etc when connected to shore power, or of course Solar Power with the controller set for LiFePo charging, Cell Balance won't be an issue for most.
LiFePo batteries will deliver so much more usable power even if only recharged to 90% SOC as compared to FLA battereis only discharged to 50% DOD.
I think that a lot of people don't understand that they don't really NEED to upgrade their converters if they want to use the LiFePo batteries as drop in's.
For those with questionable converters like the WFCO units, they might want to upgrade them to better units even if they don't upgrade the batteries to LiFePo4.
For those with Progressive Dynamic's Converters with the Charge Wizard, just adding the pendant that allows one to manually force the converter into Bulk Mode, both Progressive Dynamic's AND Battleborn acknowledge that using this "hack" will more than satisfy the cell balance needs in the batteries.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
