Old 07-05-2024, 02:42 PM   #1
Bedroom ceiling lights
2020 Sabre BHQ
Bedroom ceiling lights stopped working suddenly and the switch stopped glowing blue. Only the ceiling lights not the ones over the head of the bed. All the other 12v appears to be working. I had someone look at the switch and they said there is power to the switch but they mentioned a possible line going down to the inverter? Ideas? There is no battery currently hooked to the inverter as there are no solar panels on the trailer.
We had some kids in there and wondered if there’s any chance that playing with the switch that turns the inverter on and off remotely could have anything to do with this?
Bobbyboy is offline   Reply With Quote
Old 07-05-2024, 03:58 PM   #2
cmulvey's Avatar
Are they perhaps dimmable and the kids set the dimmer all the way down?
Another option is if the switch is getting power, you should be able to short it out (making it think it's on) and your lights should work. If they do not, it would appear that the problem is between the switch and the lights, not prior to the switch.
Christian M
2021 Forest River Forester 3011DS
cmulvey is offline   Reply With Quote
bed, bedroom, ceiling, light, roo
