Old 08-19-2022, 11:02 AM   #1
Ago
Breaker panel
Hey all, I have a 2022 forest river forester, 2401b. My wife had the air on and then started cooking in the microwave. A breaker was tripped I'm sure. Now none of my outlets work. Where do I find the breaker panel? Checked all the fuses under driver side seat, all good.
Any ideas? Please and thanks.
Ago
Ago is offline   Reply With Quote
Old 08-19-2022, 11:40 AM   #2
I don't own a Forester but try on/under the bed somewhere. Should be a black plastic door that pops open.
Jim M.
2020 Flagstaff Super Lite 26RBWS
Former: 2017 Rockwood MiniLite 2104S
2015 Silverado 2500HD 6.0L Gas
jimmarako is offline   Reply With Quote
Old 08-19-2022, 11:57 AM   #3
Ago
Thanks. Found the panel under the fridge.
All good.
Another question, I don't seem to have a way to turn "off" my air conditioner? It only displays High, Low, Auto. I don't have a panel either. So how can I turn it off?
Old 08-19-2022, 12:30 PM   #4
I can't help with turning off the AC, sorry. What did you find when you got to your breaker panel? Was something tripped? You should be able to run the AC and microwave at the same time on a 30A service. I'm assuming you have a 30A service. You'll need to shut off the water heater, and possible the convertor.
Jim M.
Old 08-19-2022, 12:36 PM   #5
Where are you seeing hi, low, auto? Is it on the thermostat or the AC itself?
Cross-threading works better than blue loctite.
Capacitor is online now   Reply With Quote
Old 08-19-2022, 12:51 PM   #6
All good.
EDIT:
I see you started another thread. I'll replay there.
What make A/C unit and do you have a thermostat?
All R/Vs are not the same. There are dozens of combinations to using an A/C unit depending on make/model/trim level.
A photo of your controls would help too.
Did you find a breaker tripped once you found the power distribution box?
If you have a 30a service, one must be mindful of the appliances used at the same time. Many folks learn to turn off the fireplace or water heater (electric element) when wanting to use things like a hair dryer or coffee maker/toaster.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=95
Old 08-19-2022, 05:20 PM   #7
Ago
Yes thanks, found the breaker. It was tripped.
I'll post a pic ofthe panel and no, no thermostat.
Ago
Old 08-19-2022, 06:11 PM   #8
Ago
I believe if you tap the Cool button, it will turn off. "High, Low, Auto" is only the fan setting.
NavyLCDR is offline   Reply With Quote
Old 08-19-2022, 07:39 PM   #9
Just curious, which breaker tripped? the main 30A? If so do you understand why and that you need to manage loads like the water heater, convertor,....
Jim M.
Old 08-19-2022, 10:42 PM   #10
10-4.
And that is the thermostat albeit connected to a remote temperature sensor.
I mentioned this (along with a photo) in their other thread asking the same question.
Old 08-21-2022, 08:35 AM   #11
Ago
Yes it was the 30 Amp. I believe it tripped because she had coffee pot on, and air and then she started using convection oven. Too much of a load I guess. So we will pay more attention next time.
Ago
Old 08-21-2022, 08:37 AM   #12
Ago
Will try that next time it is running. So what you are saying, while it "on" (cool), I can hit the Cool tab and it will turn off?
Ago
Old 08-21-2022, 06:07 PM   #13
Ago
Yes!
Old 08-21-2022, 06:30 PM   #14
Retired Old Fart
dward51's Avatar
Ago
Yep, too much of a load. That combo will surely do it, but easy fix (reset breaker and wait until coffee is done before using convection oven).
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline   Reply With Quote
breaker, panel
