Old 09-23-2020, 03:27 PM   #1
Breaker Type
Can anyone tell me what the actual make of the breakers are in the WFCO WF-8955PEC distribution panel? I would like to keep an extra on hand. I have had breakers quit working in the past (not on this rv) so I'd like to be prepared. Thanks
TerrySustar is offline   Reply With Quote
Old 09-23-2020, 03:36 PM   #2
Iggy's Avatar
Welcoome to the forum
They are standed SquareD QO type. (standard width)
SquareD is not the only one who make ones that will fit.
I personally like SquareD as I'm a retired Journey level Electrician by trade.
a single pole 15 amp single pole would be a QO-115
a single pole 20 amp single pole would be a QO-120
Etc
See picture what they look like in the back.
2012 Georgetown XL 378TS
FB Georgetown RV Club
Old 09-23-2020, 04:25 PM   #3
Head Rambler
I have a WF-8955PEC at home that I removed when I upgraded to 50 amp service and I can tell you that they are nothing like the picture above.
There is a list of approved breakers on the label in the panel. They're standard stab-on type residential breakers like in a lot of home breaker panels.
I can take a picture of the label on the panel if yours is missing.
Gotta go campin!
Old 09-23-2020, 04:57 PM   #4
My last few campers had Square D Homeline breakers. Not the QO as previously stated.
Papa Roo is offline   Reply With Quote
Old 09-23-2020, 05:20 PM   #5
Head Rambler
Here's a list of the approved breakers from the user manual.
AC Circuit Breakers (120/240 Volts)
The AC Breaker side of the WF-8900 Series Power Center is located on upper the left side.
The WF-8900 Series Power Center accepts standard residential breakers. A total of ten
breakers can be installed: one 30 Amp Main breaker and up to a maximum of nine AC
Branch circuits when using duplex breakers. A list of factory tested and approved breakers
follows. The breakers may be purchased at most big-box department stores and home
centers.
UL-Listed Main Circuit Breakers, Rated for 120V, Maximum 30A
The following breakers have been factory tested and approved for use as 30 Amp Main
breakers in the WF-8900 Series Power Center:
Manufacturer Model/Cat. No./Type
Cutler Hammer Type BR and C
Thomas Betts Type TB or TBBD
ITE/Siemens Type QP or QT
Square D Type HOM or HOMT
Murray Type MP-T or MH-T
General Electric Type THQL
UL-Listed Branch Circuit Breakers, Rated for 120V, Maximum 20A
Gotta go campin!
Old 09-23-2020, 06:57 PM   #6
Iggy's Avatar
My mistake you are totally correct.
Square D Type HOM type.
breaker
