Originally Posted by BPetz
The symptom(s) is no cabin power. Don't even have enough juice to start the generator
Probably dead batteries. I suspect that the battery disconnect was in the wrong position and the batteries were not being charged. Since you had them replaced in April 2022, they aren't being charged from shore power.
This is a motorhome, right? When you run the engine, the batteries will be charged from that engine (assuming the battery disconnect is not engaged. It will take some time to charge them though.
Your other 'work around' would be to put a battery charger on the house batteries.
Have you checked to make certain you haven't blown a fuse in the house?
