Originally Posted by Ross6250
Right & left mirrors not able to adjust. Right & left cameras not working. Rear camera works awhile after starting. I assume it is a fuse somewhere, but where. 2016 forest river sunseeker class C.
Ross
Is your particular Sunseeker built on a Ford, Chevy, or Mercedes-Benz chassis? You might want to add your Sunseeker model and chassis type to your profile or signature so people can give you answers applicable to your RV.
If you have a Ford E-series, you might want to remove the kick panel in front of the drivers knees. The wiring for the mirrors and the camera switch box may be there. When these add-on modules are installed, they often have in line fuses tucked away in the sloppy rat’s nest of aftermarket tangled wiring.
The official Ford E-series fuse panels are one under the hood, driver side, and one under the dash, in front of the parking brake pedal. The owners manual describes fuse functions.
There are probably about 100 fuses scattered around in a Sunseeker.
