Old 12-05-2020, 09:46 AM   #1
IchLiebeBier's Avatar
Camper Breaker NOT Tripping
Hi all,
I need some electrical schooling here to understand what is going on to make sure I'm not harming anything. Any help would be appreciated.
I have the trailer plugged into the 50 amp pedestal using a 30 amp dog bone. The power line goes like this: pedestal -> dog bone -> Hughes Autoformer -> Hughes Power Watchdog -> Camper. Camper is 30 amp. First time using the Power Watchdog.
The Power Watchdog shuts down the power if I exceed 30 amps. I tested it today and saw a rise to about 35 amps on the PWD app before it tripped.
My question is this: why isn't the camper circuit tripping if it exceeded 30 amps? And will that cause damage in the long run to either the camper or the PWD?
Thanks.
2019 Heritage Glen LTZ 272RL
2018 Ram 2500 CTD
IchLiebeBier is online now   Reply With Quote
Old 12-05-2020, 10:26 AM   #2
because the watchdog is before trailer breaker like a Gfi.
Thomas ho is offline   Reply With Quote
Old 12-05-2020, 10:33 AM   #3
My question would be.... why are you not concerned that the PWD waits til 35 amps to trip? Isn't that supposed to protect your rig from amps over 30?
2015 Dynamax REV 24TB class C
Reverse_snowbird is online now   Reply With Quote
Old 12-05-2020, 10:41 AM   #4
But the camper circuit breaker is between it and the stuff in the camper.
2018 Ram 2500 CTD
Old 12-05-2020, 10:42 AM   #5
That was part of my question. I thought it was more implied than that.
2018 Ram 2500 CTD
Old 12-05-2020, 11:02 AM   #6
Most breakers are not highly accurate instruments that immediately trip at their rated capacity. I've seen them take a bit of time above rated capacity before they trip. I've also seen the opposite where they trip early.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 12-05-2020, 11:13 AM   #7
Flybob's Avatar
Most likely the reason is that the Power watchdog is an electrical device with an instantaneous trigger point, while the breaker is a heat activated mechanical device that is not as fast acting. If you remove the watchdog and run the same load it will most likely trip the breaker.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-05-2020, 11:34 AM   #8
Makes sense. Thanks all.
2018 Ram 2500 CTD
Old 12-05-2020, 01:17 PM   #9
Flybob is right!
Flybob is right! In the summer of 1967 I had a co-op job (called intern now) as an electrical engineer consultant to architectural firms doing large building designs. I read a bunch of breaker specifications.
A typical breaker spec would read something like
  • Time to trip at 1000% overcurrent: 25-200 milliseconds
  • Time to trip at 120% overcurrent 20-60 minutes.
These aren't exact numbers, just something similar to how circuit breakers are specified.
Larry
Larry-NC is online now   Reply With Quote
Old 12-05-2020, 01:40 PM   #10
I am no electrician. But just because the trailer is receiving a little more to the breakers would not make them trip until you put a draw on the breaker.
Maybe the electricians in the group could verify this for me.
And you inline will not pass through more than the 30 amps so it breaks first.
campers302 is offline   Reply With Quote
Old 12-05-2020, 03:44 PM   #11
pmurph991's Avatar
Being an electrician for 30+ years, I can say that breakers are designed to handle an over current situation for a short period of time. Your Watchdog is most likely designed with tighter tolerances.
1999 Forest River - Sandpiper
pmurph991 is offline   Reply With Quote
Old 12-05-2020, 04:29 PM   #12
Good info. Learned something today. Thanks.
2018 Ram 2500 CTD
Old 12-05-2020, 05:24 PM   #13
A breaker trips on heat caused by over amp draw or short circuit. A good breaker and cool weather will allow a 30 amp breaker to draw 35 amps for a while. No way to determine exactly how long because it depends on name brand of breaker and amp draw and ambient temperatures and a lot of other conditions.
Your trailer wiring should handle the amp draw without harming the wires. The wiring is probably rated for 35 amps in the trailer anyway. Romex is probably what is in the trailer and even though number ten romex is rated for 30 amps the inner insulation is probably thhn or twhn which used as a single conductor in conduit is rated for 35 amps when calculating the derate on the wire. All this to say no worries. you also have individual circuit breaker protection with your trailer panel. You are more likely to have a surge from the pedestal you plug into hence the protection you are using to prevent that.
tgold is offline   Reply With Quote
Old 12-06-2020, 02:45 AM   #14
Always Learning
I know that I have read on here that the Progressive Industries amp meter reads higher than the actual amps being used (like you take 1/3 off of the total displayed). Is it possible that your Watchdog is the same?
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
ependydad is online now   Reply With Quote
Old 12-06-2020, 10:14 AM   #15
I have never read that and mine is very accurate.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 12-06-2020, 01:21 PM   #16
Always Learning
Here it is. Hondaman reported that his was off and that PI indicated it was just an estimate:
https://www.forestriverforums.com/fo...-a-164111.html
breaker, camper
