Originally Posted by cgilbert37
Hi everyone, I'm going to install a Victron 2000VA inverter, Cerbo GX and solar charge controller into my 26TH.
The question is : Where? There isn't enough space behind the converter. I was thinking about putting everything in the front storage compartment. This is under the bed though. Would there be any issues putting everything there? I'm also thinking about moving the batteries there.
Or is there a better place?
Thanks a lot
Just found this post and thought I would throw this out there. Under thebed may not be a good location for the batteries unless they are Li. FLA batteries need ventiulation so I dont think I would put them under the bed.
Since you are adding an inverter, does this mean you have also added solar? If so do you mind telling me where you placed your controller and also how did you run your wiring from the roof to the controller. Thanks
