To post a picture you need to use the advance feature at the bottom of the posting message. Follow the prompts.
Now I have a 2016 Cedar Creek, when in storage the batteries would drain if I let the trailer sit for a month when not in use. After the first time that I went to the trailer and the battery was dead. I installed a very cheap battery disconnect device on the negative cable. I purchase this from NAPA. This disconnect device along with the battery disconnect switch, insures that there is no parasitic losses to the battery when in storage.
But, as others have stated if your battery is being drain when in use check out your converter!
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
