11-03-2020, 08:57 AM
Champion Open frame inverter
Looking at these. Show noise level 64 Dba.
Anyone using these. We would be using in federal campgrounds
thx
John G
Bluetick1955
2015 Cherokee 264L Limited
11-03-2020, 09:09 AM
thx
John G
if your out on National forest away from others go for it . in camp ground either national or forest service or state it maybe considered loud . some are real nit-picks . others won't mind . depends on the who and where .
11-03-2020, 12:44 PM
The maximum noise level allowed is seldom quiet enough for other campers.
The good news is that sound level diminishes as distance increases.
If camping within 100 feet of another campsite my guess is that it will be considered an annoyance by fellow campers but not subject to any fine.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
11-03-2020, 01:05 PM
I am also looking at Generators. I have a Champion 1400 watt unit I use from the back of my UTY. I have discovered that they have great customer service. So Champion is my choice. And they are reasonably priced.
As to your question. In my research you may find that the noise level may be too much for you. Forget your neighbors
The difference in sound level between say 70 db and 50 db is four times louder.
Just an FYI. Your mileage may vary.
11-03-2020, 01:47 PM
Ive heard plenty that were annoying so I guess I can be like them
Bluetick1955
11-03-2020, 01:48 PM
the rated difference is 59 Enclosed to 64 open frame and about $400 diff
Bluetick1955
11-03-2020, 01:55 PM
64 Db sounds suspect for an open frame generator. I'd guess in real usage it would be significantly louder. If boondocking and the noise won't bother you, go for it. If you're in a campground, you'll likely have unhappy neighbors...
11-03-2020, 02:04 PM
It's really a hybrid open frame/inverter. Not a true open frame type and not a true enclosed inverter type. (they make several models/wattages but all are rated at 64 DB - until you get above 6kw)
I heard one of these running for the first time last month. At first, I thought it to be pretty quiet... until a load was put on it... not so much then.
Days Camped: '18=51 ☼ '19=58 ☼ '20=110 ☼ '21=21
11-03-2020, 02:11 PM
I have found that a lot of them don't really care about my happiness. We prob would not use much. My wife glamps but like last week we lost power fro 2 days and we could have stayed in camper. I have a generator but not inverter. Concerned about frying camper electronics
Bluetick1955
11-03-2020, 02:14 PM
Great attitude. Enjoy your generator.
11-03-2020, 03:01 PM
The hybrid Champion is only 1 decibel quieter than the basic Champion 3500w open frame contractor-style generator that only costs $300.
I own one of those and there's NO way I would use it in a campground. Boondocking or dispersed camping, sure!
That hybrid Champion is definitely not quiet, like its regular inverter siblings.
BIG noise difference between 64db and 54db.
11-03-2020, 03:03 PM
Wish I could hear one. The enclosed is 59 dba. the 4000w open is rated 64
don't know id 3000w is enough fro AC and other
Bluetick1955
11-03-2020, 03:32 PM
I run a 13,500 bty AC on my Champion 3500W inverter (closed and quiet) as well as the microwave.
I had a 3500 W open frame which was a lot quieter than most open frame generators but not really campground friendly.
The enclosed Inverter is more than quiet enough for campground use and for battery charging it will run on "Eco Mode" which is very quiet (for a generator).
2004 Nissan Titan
11-04-2020, 08:00 AM
Brake is on left
64 Db at what distance and load? That is the real question. At 100' and 0 load it is not that great. Regardless of brand, a lot of folks keep their genny in the truck bed (myself included) and you literally cannot hear it running. Of course that depends on the generator.
11-04-2020, 12:58 PM
I have 15k AC
Bluetick1955
11-04-2020, 05:55 PM
I have 15k AC
I run our 15k Coleman A/C with my 3500w inverter generator.
11-04-2020, 06:27 PM
Brake is on left
Yup. I'll run the AC and water heater for a while. Once the water is hot I will turn that off and can use the microwave.
11-06-2020, 06:31 PM
My understanding is that sound levels are measured on a logarithmic scale. So 60 decibels would be 10 times the sound of 50 decibels. And 70 decibels would be 100 times the sound of 50 decibels. Really think OP would be happier with an enclosed inverter generator. I agree that champion is a reasonable option.
11-06-2020, 07:50 PM
Predator 3500 inverter generator runs my 15k A/C, Tv's, associated satellite receivers, sound system and residential fridge. $789 when on sale.
https://www.harborfreight.com/search?q=predator%203500
2014 Sanibel 3250
11-06-2020, 08:28 PM
Yes, an increase from 50db to 70db is 100 times the sound pressure, but is perceived as 4 times louder to the human ear.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 230 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre - Tow Package
Boon Docking 99% of the time.
