01-28-2017, 12:39 PM
Changed t-Stat, something wrong
Researched on here but can't find answer. AC and heater run at same time.
Replaced Dometic Analog T-Stat with Honeywell RTH221B T-Stat,
Dometic wiring: Red-7.5V
Yellow-AC
White-Furnace
Blue-Hi Fan
Brown-Low Fan
Green-Ground
Connected wires to Honeywell: Red-taped
Yellow- "Y"
White- "W"
Blue/Brown- "G"
Green- "RC"
Did it this way as I read another article that wired it this way but was using a hunter T-Stat.
R and RC have a jumper that I left alone. Heater works great even with AC blowing air, Fan switch blows air. I tried AC auto switch both nothing happened. Leaving for work assignment next week, hope to get it fixed. Probably wrong wire placed but didn't experiment not wanting to mess something up. Thanks
01-31-2017, 10:27 AM
It looks like you have it wired correctly.
Did you set the jumper for gas heat? Though I don't think that'd be the problem?
There's not a stray wire between the 'W' and 'G' terminals is there?
Gotta go campin!
02-01-2017, 02:20 PM
I looked inside cover switch, it was on electric/heat pump, other one was gas so i switched it to gas last night and i think that fixed the problem. Will test tonight after doc appt. Thanks for the info, appreciate it very much.
02-01-2017, 03:07 PM
Remove the Jumper. The Heater and AC are totally separate units.
B and B
02-02-2017, 05:28 PM
Thanks guys, it is fixed. Appreciate it.
02-02-2017, 06:04 PM
By what? Removing the jumper, or the switch to gas or both?
02-02-2017, 06:18 PM
Yellow-AC
White-Furnace
Blue-Hi Fan
Brown-Low Fan
Green-Ground
Yellow- "Y"
White- "W"
Blue/Brown- "G"
Green- "RC"
I understand you've gotten it working, but something about your wiring makes no sense. You say you taped off the red wire, which should be the positive power supply. so that makes no sense. You attached the ground wire to RC, which is where the positive power (red) wire should go to. I've attached a diagram for my RTH111B. The ground wire is unused because the old thermostat wasn't battery powered, so the positive DC voltage not only ran to the furnace and AC when the T-stat told it to, but it also powered the T-stat's brains, using the ground wire for return (negative). The furnace and AC have separate returns (negative) that don't go to/from the T-stat.
The T-stat is basically a switch that connects R to either W (furnace) or Y (AC) when called upon by the temperature. With batteries powering the brains, there's no need for a ground wire.
You'll see I also installed a switch to allow either fan speed to run.
2011 Traverse LT, 3.6L, FWD
02-03-2017, 07:29 AM
The difference is that you have a Coleman and he has a Dometic. Dometic, in their infinite wisdom, switches the negative side of the circuit and not the positive side. Therefore, you have to hook the negative wire to R/RC to get it to work.
The thermostat doesn't care because it's just flipping a switch (relay/triac) to make the connections.
Gotta go campin!
02-03-2017, 09:49 AM
Took jumper out and left green wire to RC but only 1 unit worked. Green wire to R and the other unit worked. Put jumper back in and green wire back to RC, flipped a switch to gas (not electric/hey pump) and each unit worked. I think initial problem was not flipping the switch to gas. Thanks
02-03-2017, 12:09 PM
Thanks for letting us know that you tried removing the jumper and it split the units, which is exactly what should have happened.
Gotta go campin!
02-03-2017, 03:50 PM
Aha! ("I see," said the blind man - as he picked up his hammer and saw!)
I'm assuming the furnace must also be wired to be switched on the negative side, then, too.
02-06-2017, 11:17 AM
That is mostly correct. There's a relay in the ceiling box that sends power to the furnace and that relay has the negative switched.
Gotta go campin!
02-06-2017, 11:30 AM
So how do they handle the furnace?
02-07-2017, 10:04 AM
There are relays in the A/C ceiling box for the A/C fan, compressor and one for the furnace. when in furnace mode, the relay powering the furnace, switches on and off in response to the thermostat switch opening and closing. So the thermostat powers the relay and the relay powers the furnace.
Gotta go campin!
02-07-2017, 12:03 PM
So they run the furnace T-stat wiring to the AC? Weird. If I were trying to follow the wiring, I would never have been expecting that.
