Old 05-17-2021, 09:49 AM   #1
Murph60's Avatar
Charging/ Battery Question
New Rockwood A122S owner here and I am finding out all that I don't know. I picked it up on May 11th and our first trip will be over Memorial Day weekend. If the TT is sitting for only 2-3 weeks, do you put a charger on it, hook up your generator, just pull the negative cable or don't worry about that short a time frame.
BTW, if it matters, using 2 Group 27 AGM batteries.
Murph60 is offline   Reply With Quote
Old 05-17-2021, 10:02 AM   #2
Blackrock's Avatar
Depends on where you have it parked. I keep mine lugged in at home on a 30amp service. You can also plug into a standard 110v with an adapter and keep the batteries charged up through the converter.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Illegitimum non carborundum
Blackrock is offline   Reply With Quote
Old 05-17-2021, 10:03 AM   #3
I always either unhook the batteries to prevent them from draining, or plug my trailer in to keep them charging. It may be overkill, but I do that whether itís 3 days or 3 weeks between trips.
ScotNH is offline   Reply With Quote
Old 05-17-2021, 10:06 AM   #4
Murph60's Avatar
Thanks. I am also thinking of installing a battery disconnect.
Old 05-17-2021, 10:13 AM   #5
Murph60's Avatar
right now both batteries read 12.92 volts
Old 05-17-2021, 10:22 AM   #6
Youíll get different opinions. Much has to do with whether electricity is available where you store it. If it is many will say just leave it plugged in. If electricity is not available it is best to ensure the batteries are fully charged and then disconnect them. Fully charged batteries without a load will last months.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 05-17-2021, 10:38 AM   #7
Chewman's Avatar
Don't drop batteries below 12.4 volts
Interstate battery says 12.4 is 50% capacity on batteries, which you should not go below.
When you are running electrical things the batteries can drop to 11.9 volts and will bounce back up to 12.4 volts without a draw on them. So 11.9 is the lowest point you should ever drain them to. It is my understanding that if you do go below that you don't ruin the batteries, you just shorten the life. Once again this information came from Interstate.
I plug my trailer in about once a week to charge the batteries. I don't know if keeping them charged fully is best or letting them run down some and then charging them.
Your A122S looks like a great trailer, have a wonderful weekend trip!
2020 Geo Pro G19FD
2018 Ford F150 2.7L V6 ECOBOOST
Chewman is offline   Reply With Quote
Old 05-17-2021, 10:50 AM   #8
Murph60's Avatar
Can I hook up my trickle charger with Battery connected to TT or do I need to disconnect before charging?
Old 05-17-2021, 10:58 AM   #9
Just hook it up. No need to disconnect batteries.
Lead acid batteries will last longer and retain more capacity if kept fully charged. Battery maintainers are great for this task as they don't provide so much current that electrolyte boils.
Lithium batteries, on the other hand, prefer to be stored with a partial charge due to their chemistry.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 05-17-2021, 10:58 AM   #10
No need to disconnect, connect your trickle charger, no harm. It will maintain the battery.
2015 silverback 31IK
2015 Chevy 3500HD
kcmusa is offline   Reply With Quote
Old 05-17-2021, 02:20 PM   #11
Murph60's Avatar
really stupid question, but after it is charged and I disconnect the neg to prevent draw when it is idle, do I only need to disconnect the neg where the TT negative is connected to or do I have to disconnect both negatives in a two battery set up?
At some point I will be installing a disconnect.
Old 05-17-2021, 03:06 PM   #12
Iím assuming two 12 volt batteries connected in parallel.
You should have a couple of jumper cables between the two batteries. One between the two positive terminals and one between the two negative terminals. Just leave those jumpers, no need to disconnect them.
Then you should have an additional negative cable that goes from one of the battery negative terminals to the chassis ground. Make sure you only have one additional negative cable connected to the battery negative terminal. This is the one that you want to disconnect!
Old 05-17-2021, 03:15 PM   #13
If you have electricity and a charger with a float phase, then leave them on the charger or leave the trailer plugged in. If not, make sure they are fully charged and then disconnect them once parked. Either a disconnect switch or remove the trailer negative connection (not the parallel jumper). If there is more than one negative lead (hopefully not), remove them all so there is no load.
Jim and Michelle + Family
Rancho Cucamonga, CA
2020 Rockwood Roo 233S
2013 Ford F150 SCrew, 5.0L, tow upgrade
Old: 2003 Jayco Kiwi 23D
Jim_74 is offline   Reply With Quote
Old 05-17-2021, 03:52 PM   #14
Murph60's Avatar
Yes, installed in parallel. I have the TT negative to battery A, TT positive to Battery B. Neg to Neg jumper and pos to pos jumper. So I only have to remove neg from TT. Got it and thank you all.
Old 05-18-2021, 03:06 PM   #15
Murph60's Avatar
One more stupid question. If they are connected in parallel, with house negative disconnected, if I hook up the charger to one battery will they both charge? Or do I need to charge each one separately. Sorry and thanks.
Old 05-18-2021, 07:55 PM   #16
Those jumpers between the two positive terminals and the two negative terminals effectively turn the two batteries into a single larger battery, with twice the capacity. Leave the jumpers in place. Put the positive lead from the charger on a positive terminal and put the negative lead from the charger on the negative lead of the other battery.
Old 05-18-2021, 08:41 PM   #17
Murph60's Avatar
Thanks Much. That makes a lot of sense.
Old 05-19-2021, 07:26 AM   #18
https://lh3.googleusercontent.com/pr...a266JDAYcWff6P
Wiring diagram
2015 Chevy 3500HD
Old 05-19-2021, 01:20 PM   #19
Murph60's Avatar
So I let the batteries rest, disconnected neg, to get a more accurate reading. It is at 13 volts, compared to 12.92 yesterday when connected. Is 13 to high to put a trickle charger on before I go camping next weekend? In other words can you damage the battery by charging if it is near or above 100%. Would the smart chargers take that in into account?
Thanks. Just wondering if is advisable to put them on the charger before we leave since there is no AC at this campground.
Old 05-19-2021, 02:19 PM   #20
They appear to be full. I wouldn’t even bother with the trickle charger. They should hold their charge for months if fully disconnected. Since you appear to have power available for the trickle charger just connect the batteries back up the day or night before you leave and plug your normal shore power cord into the electric source and let your built in converter top them off. But this is just me. Others may have different suggestions.
battery, charging, question
