Are you sure your converter has switched? Do you see the blue LED? You can measure the charging voltage at the converter using the test point on the back of the battery fuse to verify it's putting out around 14.6V. Don't measure it at the battery - too much voltage drop to get an accurate measurement, even with good cabling.
2023 r-pod RP-192 with Beast Mode suspension
600W rooftop solar, 300Ah LiFePO4 battery bank, 2000W inverter.
Uses an electric coffee maker when boondocking.
"Never underestimate the power of human stupidity."
-Lazarus Long
