Old 07-27-2020, 04:01 PM   #1
Clearance lights will not shut off.
I have a 2019 Sunseeker MBS.
There is a thread about the Curt controller causing issues. I do not have the Curt controller - mine is a Hopkins. It is located in the same place as being described in that thread - rear bumper.
My issue is that the two clearance lights at the lower rear of the motorhome never seem to turn off. They glow so lightly that you can barely see them - but they are lit.
  • I disconnected the controller and they remained lit.
  • Removing the 25amp fuse in position #10 from the fuses under the drivers seat will kill them.
Suggestions?
Odd Jaun is offline   Reply With Quote
Old 07-27-2020, 04:13 PM   #2
rsdata's Avatar
I have come across odd lighting patterns in MH bodies in the past, usually older ones. Often it can be traced to corrosion either in that light socket or another light in that same circuit. What other lights are affected when removing that fuse? Check those also. Use a scrap of sand paper and a tooth brush to clean up the inside of the metal light sockets to fix. Hit it with a little WD-40 when clean.
2014 Shamrock 183
Old 07-27-2020, 04:17 PM   #3
That fuse controls all the clearance lights, turn signals, and tail lights as well.
light
