FR Warranty Let Us Down
Thanks for confirming the monitor is not located where it should be and where it is in other similar RVs. I spoke with an individual from the Forest River Warranty division yesterday. He said FR had worked with the monitor manufacturer and "others" in RV manufacturing on the location of the monitor; that putting the monitor in the dinette area (per manufacturer instructions) would cause false alarms when cooking with LP; that the monitor was probably picking up hair spray, cologne, floor cleaner vapors, etc. No, No, No. The RV is spot cleaned with hot water (we've never used the shower, the oven, the stove top or the microwave, as we've only slept in it overnight outside our son's house and on the road in Walmart parking lots so it hasn't had a chance to really be used); neither of us uses hair spray or cologne because of my asthma. Maybe the materials used in the construction of the RV or the batteries are out-gassing. No matter what, the gentleman who called was condescending and FR isn't going to do anything. Sounds to me like there was a problem with the monitor alarming for other reasons than CO/LP and FR moved the monitor to the bed base without making any design changes (like moving the storage door and putting the monitor in an exposed section of the base bed. Now that there's a problem with the slide room and it can't open, we have no access to the monitor. Worse part? The FR rep told me the monitor was hard wired (yes) so there isn't a battery - wrong - the RV dealer had to change the back up battery because it ran down after we cut the power to the coach. I'm drafting a report to file with the transportation safety board this weekend!
