Do you have a surge protector that could check the conditions of that campsite plug in? They are under $50 and can check for reverse polarity, bad ground, open neutral, etc.
The actual converter is behind a metal panel where your fuses/circuit breakers are located. The panel comes off. You've reset the circuit breakers and removed the fuses to see if they are all correct? Do you have a battery disconnect switch? The battery won't charge if that is disconnected.
2015 Dynamax REV 24TB class C
