Old 11-01-2013, 01:17 PM   #1
Ret E-9 Anchor-clanker
donanddona's Avatar
Color Coding
I'm looking for the wiring identification coding for my 5th wheel Flagstaff it has a seven pin TT to TV. Trying to trace down a clearance/running lights problem. I'm not ruling out a potential ground problem but need a start. I do have a TV tester (cheep), it shows that power is avail. I don't have clearance lights most of the time and stopping to unplug and re plug over and over is worthless. However they will come on while driving and sometimes when hooking up they will come on. Help!!!
donanddona is offline   Reply With Quote
Old 11-01-2013, 01:34 PM   #2
"Roughing it since 2000"
I would start with the plug. Open it and make sure all screws are tight against the wires and have good, clean connections. Then I would check the plug connection on both TV and TT for corrosion or anything that may be obstructing the connection.
2007 831FKSS
1996 F-350 CC LB Dually
2007flagstaff is offline   Reply With Quote
Old 11-01-2013, 05:21 PM   #3
If all the lights are affected, brake and turn, check the ground wire.
Rockwood 8282 WS
2012 F-250 6.2
farfetched is offline   Reply With Quote
Old 11-01-2013, 05:45 PM   #4
Iwannacamp's Avatar
Cheap check... Booster cable frame to frame between.
2017 Puma 297RLSS
Old 11-01-2013, 05:48 PM   #5
Phat Phrog Stunt Crew
awwall's Avatar
See if this will help...
Name:	plug wiring.jpg
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 11-01-2013, 06:51 PM   #6
aka Windjammer2012
Crankshaft's Avatar
X2...If its not corrosion at the connectors and you have a molded plug check the wire connection where the cable at the other end (meaning there may be a junction box under the front of the trailer where the cable connects to the trailer wiring). It might be a bad connection at that point.
Wayne & Vonnie
Layla (American Eskimo dog)
2012 Windjammer 3008W
2004 GMC 2500 HD CC Longbed
Crankshaft is offline   Reply With Quote
