Old 04-05-2019, 11:32 AM   #1
Converter fuses
I have a 2013 2801QS which has been in storage for a month and the batteries are losing voltage, down to 11.4. So i charge for 2 hours with the generator with converter putting out 14.4V. I brought it home and plugged into shore power and the EMS said it was drawing 19Amps AC with only the converter on. So i charged for a day with a 6Amp portable charger. Now when plugged in to Shore power the EMS says 0 Amps AC and the batteries are at 12.5V. When reading voltage at the reverse polarity fuses the converter side of the fuse reads 14.1V and the battery side of the fuse reads 12.4V is this a normal reading for these fuses. Converter is PD4560. Never seen a fuse read different voltage on each side.
2014 Forester 2801QS
2010 Kia Soul
monte is offline   Reply With Quote
Old 04-05-2019, 03:23 PM   #2
Is the fuse good? Just never heard of two different readings on the same good 12 volt inline fuse. How can that be? Maybe someone can explain.
DYNAMAX 2016 FORCE HD
houstonstroker is offline   Reply With Quote
Old 04-05-2019, 03:32 PM   #3
Not possible. Converter is on a 15 amp breaker. only draws about 2-3 amps when working. You probably saw 1.9 amps AC draw.
Not possible. Voltage will be the same on both sides. Fuses don't use electricity. It's just a piece if wire inside plastic. The place to check converter output is a the large battery wire connections of the converter.
Old 04-05-2019, 03:58 PM   #4
Fulltime family RVer
The Progressive Industries EMS has been reported to over repeat amps by as much as 1/3. So that 19 amps might really have been 13.
But, my converter is also on a 20amp breaker.
Old 04-05-2019, 07:29 PM   #5
The breaker is sized to protect the wire size that it is on not the equipment it is hooked to.
I used this as an example WFCO WF8955PECB Black 55 Amps Power
It draws 8 amps under load. Probably the 2-3 I stated at idle.
Don't know what is in my trailer but it is on a 15 as is everything but the AC.
No way his was drawing 19
Old 04-05-2019, 07:33 PM   #6
It will if it is blown. One side,is,reading the converter output and the other the battery. If the fuse is blown that is what you would read. Check,the fuse.
2016 Siverback 33IK, Towed 40K+ miles
Andersen Ultimate Hitch
RadMini Stepthru eBikes
Old 04-06-2019, 07:36 AM   #7
Had to move the motorhome back to storage so no shore power but will check the fuses today. There are 3 25amp fuses for the reverse polarity circuit all reading the same so all 3 would have to be blown. I'll check this weekend to see if I get the same readings with the generator. Thanks for all of the reply's, will post what I find later.
2010 Kia Soul
Old 04-06-2019, 08:55 AM   #8
Only two fuses. One for each wire. One positive and one negative. And yes only one of the two can be blown.
Old 04-06-2019, 10:13 AM   #9
fonzie's Avatar
Some converters have 3 - 25 amp polarity fuses, see this thread.
http://www.forestriverforums.com/for...-155721-2.html
Fonzie
Nights Camped:2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42) 2019(28)
Old 04-06-2019, 10:37 AM   #10
Flybob's Avatar
If you have significantly different voltages on each side of a fuse the fuse is blown.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-06-2019, 10:37 AM   #11
Well I guess everyone in that thread learned something new didn't they? I'd like to see a wiring diagram to understand how and why 3 are needed. Now we need to tell people to look for two or three fuses
Old 04-06-2019, 10:41 AM   #12
[QUOTE=dalford;2064479]It will if it is blown. One side,is,reading the converter output and the other the battery. If the fuse is blown that is what you would read. Check,the fuse.[/QUOTE
True. The only way to get two different readings.
Old 04-06-2019, 11:53 AM   #13
So all 3 25amp fuses were blown. I recently changed out both batteries and thought that I was extremely careful to not allow any wire to not touch any place it was not supposed to. However the fuses did not blow for no reason. So after I replace the fuses I will run generator and see if everything works. Once again thanks for the reply's. This forum is great. A wealth of knowledge.
2010 Kia Soul
Old 04-07-2019, 01:29 PM   #14
Went out to put reverse polarity fuses in today and with no AC power to the converter the voltage reading on the converter side of the fuse holder is 0 VDC and the batt side is 12.3 VDC. I went to put the 1st of the 3 fuses in and got an arc between the fuse legs. Barely touched it so didn't blow the fuse. Should I get an arc when putting the fuse in? When the converter was plugged in to shore power it was reading 14.1 VDC.
2010 Kia Soul
Old 04-07-2019, 01:39 PM   #15
Normal if there is any load still attached to the circuit. Also normal when the "blown fuse indicator" led circuit charges. Usually the arc is small unless on a circuit that draws a fair amount of current like a fan, etc.
Only way to stop these small "fuse arcs" on 12 volt side is to disconnect battery and switch off converter power supply. I wouldn't bother unless the fuse blows immediately after you replace it. Now you have a repair issue to deal with.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
Old 04-07-2019, 04:02 PM   #16
Thank you TitanMike, That's what I thought but never hurts to get a second opinion.
2010 Kia Soul
Old 04-09-2019, 09:21 AM   #17
Head Rambler
AND, There are some converters that have four(4) reverse polarity fuses.
Gotta go campin!
converter, fuse
