07-21-2019, 09:10 AM
#41
Yea i ment converter i sleep 4 hours and now in a oven aka work
07-21-2019, 09:15 AM
#42
Hopefully. the converter is all that you lose from the incorrect connection you attempted to make/made. (still cannot understand how you got the ground pin into the neutral slot)
If you will reread all of the previous posts from everyone, including links, you should be able to educate yourself on how to never allow this to happen again.
It's painful, and we do understand. It happens, and you just have to get it fixed and try to move on past it. Being painfully honest, I would let an experienced RV tech replace this converter, and maybe not attempt it yourself.
Also explained previously, are things you may need to keep an eye on....as they could give up the ghost in the near future from the 240 volt episode.
2011 Flagstaff 831 RLBSS
07-21-2019, 09:23 AM
#43
That wasnt the exact plug i plugged it into just took quick pic thought it was same
07-21-2019, 09:26 AM
#44
Well, this is getting somewhat frustrating then. If you cannot give accurate information, you cannot get accurate replies.
You have to help us help you.
If you thought the outlets were the same, then this does show how inexperienced you may be in electrical terms. I definitely and double down now on the advise of letting an experienced RV tech work on this RV.
07-21-2019, 09:30 AM
#45
I didnt relize it till after posted and posted picture of the correct one
07-21-2019, 09:32 AM
#46
I didnt relize it till after posted and posted picture of the correct one Attachment 210421
Who wired this outlet you NOW have changed to? Where is the circuit breaker to it in the home panel? Is it single pole or double pole circuit breaker (please don't guess). That appears to be a brand new installation.
Reread the second part of my post #33, which explains what has probably happened with this installation you are now showing, and it's still incorrectly wired for 240 volts.
07-21-2019, 09:35 AM
#47
We just bought the house like 3 months ago it inside the building
07-21-2019, 09:39 AM
#48
Please post a photo of the breaker (in the breaker box) that controls this outlet.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
#49
You need to test the outlet. If you have 240 volts across the two slots, it's wired incorrectly.
TT-30R The voltage between the Hot lead at 7 o'clock and W 120-volt, Hot lead and G 120-volt, W and G 0-volt
07-21-2019, 09:48 AM
#50
I am at work at moment
07-21-2019, 09:51 AM
#51
Okaaaaay, but where did the picture in post #45 come from then?
07-21-2019, 09:56 AM
#52
Always Learning
Do you ever feel like some people are intentionally being obtuse?
There have been a rash of threads lately where someone asks a question and then gives back 1/2 answers, misleading answers, and in this case, made up pictures. Between this post and the toy hauler sway guy- something smells fishy.
07-21-2019, 10:19 AM
#53
From my post on fb group i made wben someone asked for pic of it but i forgot to post it on here is all
07-21-2019, 10:23 AM
#54
Always Learning
Originally Posted by tjwdj
Your info is great! I'm still trying to understand the workings of the surge protector for my 50 amp RV. I'm a widow now and I desperately want to do things correct and keep my RV safe and well running. I need 'idiot pictures' at times and these are great. This forum helps me at times too...Thanks again!
Make sure your surge protector is really an EMS and always use it. Always, always, ALWAYS. An EMS would not have allowed power into this rig and would have showed an error that would have prevented damage to anything.
See this:
https://learntorv.com/what-surge-pro...est-for-my-rv/
For the OP- my apologies for my last comment. You, too, should invest in an EMS.
07-21-2019, 10:56 AM
#55
Each slanted plug is getting 110 middleis ground/neutral
Reviewing your previous posts, you stated the above.
No matter which pic you were supposed to have posted, this would be wrong if BOTH "slanted plugs" have 120 volts when measured separately.
This would indicate you have 240 volts.
